06-22-2023, 08:40 PM | #1 |
Rep 13
What to do about cracked rim
Hi all,
I've got a 2019 X5 xdrive50i with style 742M wheels. My rear passenger tire started leaking air, so naturally I took it into Costco to have them take a look at it to see if a tire needed to be repaired. Unfortunately, what they discovered is that there is a hairline crack on the interior surface of the rim and they showed me that's where the tire is leaking. Is something like this generally repairable? Or is it usually necessary to replace the rim? I should have taken a picture when I was looking at it but I didn't. It looks like a very thin crack. Thanks for your help. |
06-22-2023, 09:26 PM | #2 |
254
Rep 320
If it was my car I wouldn't repair it. See below info from tire shop.
Can A Cracked Rim Be Repaired Yes, and no. A cracked rim can be repaired if the crack is small and situated in an area in which it does not completely compromise the structural integrity of a wheel. This means that a singular hairline crack located on the middle or at the rear lip of the wheel can be welded without needing to replace the wheel. On the other hand, if the crack is large, goes in multiple directions, is located on the front of the wheel, or severely compromises the structure of the wheel in any other way, it can not be repaired effectively. In any case, there is no guarantee that a cracked wheel is ever going to be as good as it was before, so be sure to take your wheel to an experienced shop for more info on how and if you can repair it. |
