06-13-2023, 11:22 AM | #1 |
2063
Rep 1,559
Took my wife's Mazda in for an oil change and they vacuumed out the oil from the dipstick, which I'd never seen before. All other times it was a typical gravity drain. Don't guess it would work for our cars since we don't have a dipstick shaft. They vacuumed out about 5.3 qts when the capacity is only 4.5. I asked why it was over capacity and they asked who filled it last and I replied "you did". LOL
The level on the dipstick always showed right at the full mark, so I never had any indication it was over capacity. Obviously not all was drained and they simply add the required 4.5 qts back in. Now it makes me wonder about the M240i and whether the electronic measurement would show us if it was over capacity, or does the green bar max out at the full mark? With the ZTK package having an additional oil cooler it also makes me wonder how much oil is not being drained. Just an observation and something to keep in mind if you do your own oil changes on the M240i, like I do. Ours calls for 6.9 qts, and I've always added 6.75 qts just to make sure I don't overfill. Now I may change my routine to 6.5 qts and see what that registers on the electronic measurement. |
06-13-2023, 12:49 PM | #2 |
5948
Rep 3,019
Drives: A Family Sedan
If the manual calls for 6.9 quarts, that’s how much you should put in during oil changes.
Obviously you’re fine putting half a quart less if wanted, but that means the oil will last shorter, and you run a higher risk of oil starvation during turns on a track, for example. There’s no reason to put in less than indicated. |
06-13-2023, 01:20 PM | #3 | |
2063
Rep 1,559
My point is it appears there's a considerable amount of oil left in the engine/coolers/lines during a gravity drain on some cars, and now I'm curious how much is left in our cars. Also, curious if our electronic measurement will show us anything ABOVE the full line? |
06-13-2023, 01:26 PM | #4 |
1746
Rep 2,090
I thought everyone had moved on from vacuuming out oil. I believe it tends to spray oil all over the engine internals on the way out, also spraying all the crap which would ordinarily gravitate to the bottomed and be drained away.
06-13-2023, 01:51 PM | #5 | |
2063
Rep 1,559
Not sure how it would spray oil all over the engine as a long tube is inserted down the dipstick shaft to the bottom of the oil pan, which then sucks it out. Not clear on where/how the spraying would occur? |
aiursblade81.00 |
06-13-2023, 02:22 PM | #6 | |
740
Rep 706
What is interesting is my manual does not state the oil capacity. In three locations it warns against too much oil. Even in the "tech data" section (which is woefully inadequate) the oil capacity is omitted. Perhaps i missed it...but i can find no reference to oil capacity in the owners manual (2022 US). I think they expect all BMW owners to have dealerships change oil as that complex operation is too technically involved for us. |
06-13-2023, 02:49 PM | #7 | |
2063
Rep 1,559
What's funny is this car probably has the easiest oil change of any car I've owned. |
06-13-2023, 03:34 PM | #8 | ||
5948
Rep 3,019
You are way overthinking this. And the 7.4 quarts example is a strawman argument, since no one is talking about it. Quote:
I’ve been doing my own oil changes in BMWs without dipsticks for several years and hundreds of thousands of kilometres and never once overthought about this… 7 quarts/6.5 litres and you’re good to go. I guess the old adage that oil discussions are never ending rings true here. There’s always something new coming up… I’ll see myself out |
06-13-2023, 03:45 PM | #9 | |
1746
Rep 2,090
Would you expect it to have the spark plug gaps in there too |
06-13-2023, 03:46 PM | #10 | |
81
Rep 68
No detrimental effects whatsoever, and it got all the oil out same as a normal drain. Was even mentioned in the VW service guidelines. |
M2siast5947.50 |
06-13-2023, 04:48 PM | #11 | |
5948
Rep 3,019
These omissions reflect the times we live in… Plus, BMW charges money for service manual access and shut down whoever was sharing the information. We can’t even torque the wheels after a wheel change over without information. |
06-13-2023, 04:53 PM | #12 | |
2063
Rep 1,559
The 7.4 quarts vs. 6.4 quarts came from the .5 quarts difference between what was vacuumed out and what the recommended volume is in my wife's car. I used that .5 quarts as the example for our car's volume of 6.9 quarts of being .5 quarts above vs. below the recommended volume. Apologies the simple math came across as a "strawman argument". |
06-13-2023, 04:59 PM | #14 | |
104
Rep 142
I had 3 VW/Audi diesels over the years and the Pela 6000 was everybody's favourite extractor. FWIW - I could always get more oil out with the Pela extractor compared to regular gravitational drain. By how much - depended on the shape of the oil pan, location of drain hole, etc.
'17 - Boxster 6SP/SSK/Brombacher
'23 - Polestar 2 '23 - M240 xDrive (winter car) |
XC3LLR82062.50 aiursblade81.00 |
06-13-2023, 05:00 PM | #15 | |
5948
Rep 3,019
Every engine has a MIN/MAX range, and that range is 1 quart in BMW engines. So, running 0.5 below MAX is totally fine. 0.5 above MAX, not so much… I’d rather do 7 quarts than 6.5. But not 7.5 over 7 (or even 6.5) |
06-13-2023, 05:02 PM | #16 | |
2063
Rep 1,559
I'd be tempted to use the vacuum method with this car if we had that option. And with the oil filter's access under the hood, no need to ever get under the car. |
M2siast5947.50 aiursblade81.00 |
06-13-2023, 05:07 PM | #17 | |
2063
Rep 1,559
This is what makes me suspicious of a lot more oil being left in the engine during an oil change, and then adding 6.9 qts could be taking us well over 6.9 qts actually in the engine. Does the electronic dip stick show us anything over full (max)??? |
06-13-2023, 05:15 PM | #19 |
5948
Rep 3,019
06-13-2023, 05:20 PM | #20 | |
5948
Rep 3,019
You said it registered full with 6.75, which I trust. It would show full from 6.5 to 7, based on my experience. Even less than 6.5 would register as full I believe. It doesn’t mean it would show as “overfilled” if you had done 7. Hence my “you’re overthinking it”. No need to overthink it. 7 quarts and call it a day. So, the way the car measures the level is by observing HOW LONG the oil goes from one temperature to another when it heats up. Many factors at play for that sensor to read something different based on how long the oil took to go from 40 to 180 degrees for example. That’s why there’s a big margin for error. The capacity is what we should put in the engine, and it takes quite a bit more to overfill. |
06-13-2023, 05:26 PM | #21 |
5948
Rep 3,019
BTW, the N52 takes 6.5 litres as well. No turbo. No oil cooler in some models.
So does the N54 (2 turbos). And the N55. And the B58. And the S58. See where I’m going? |
XC3LLR82062.50 |
06-13-2023, 05:41 PM | #22 | |
2063
Rep 1,559
