06-01-2023, 10:58 AM | #1 |
Idiotic lifter of heavy stones...
1957
Rep 2,135
Drives: 2015 F31 325D M Sport touring
M Performance pedals & fitting
I've got these in the garage, obviously no fitting instructions (BMW would probably charge more for em )
Had a look on Googles and Youtubes and can see some drilling is required But... Has anyone fitted these without doing any drilling, but using a strong double sided tape instead (brake and accelerator pedals); the dead pedal just sticks on? Cheers
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
06-01-2023, 01:40 PM | #2 |
86
Rep 92
Hey Dan,
I can’t say I have. The accelerator pedal was far easier than the brake when using the little tapping screws. The brake pedal had a nut on the back. It’s not the most comfortable of jobs. The only thing I did double side sticky tape was the matching footrest which from memory came pre-taped. A bit of IPA later and 3 years later that thing hasn’t moved. I’ve had success in the past using Araldite to glue some Mugen pedals to an EP3 Civic Type R. I’m sure wherever that car finds itself these days they’re still firmly attached! |
danb19791956.50 |
06-01-2023, 02:23 PM | #3 | |
1957
Rep 2,135
But the thinking is that I can remove all this trim if/when it comes to selling the car (if/when that ever happens) & revert back to OEM factory etc and then sell the parts on to bring some money in etc Everything I've bought is OEM BMW; so not cheap, even 2nd hand! I also had gen Mugen pedals in my EG6 SiR-S (Jap import) and DC5; both sets bought via ICB Motorsports in the States, much cheaper than anywhere else I'm in no shape to be doing footwell gymnastics currently; but will weigh up some options soon and see what works best Thinking thin strips of Gorilla tape etc
06-01-2023, 04:35 PM | #4 |
86
Rep 92
Yeah i follow your logic chap, it’s always hard to make money back from modifying cars so to get something back is some reasonable man maths. The brake pedal has the rubber cover on it so in theory you could when it comes to splitting parts, just put the rubber cover back on and nobody would ever know the cars had the M Performance pedals fitted previously. Different story for the accelerator as you’d see the three tapped screw holes if someone was really scrutinising the car at potential sale time.
You could probably get away without coding by purchasing a second accelerator pedal that you could unplug and swap over but as you say OEM parts ain’t cheap. I think you’d also see success with a bit of Gorilla tape. I fully respect from other threads where you’re at with regards to your recent surgery so yeah mate some things to weigh up for sure. I’d of loved a low mileage pre facelift DC5 with C Pack! |
06-03-2023, 04:22 AM | #5 |
830
Rep 1,065
I'm not sure glue would hold up in the long term mate. Do a few emergency stops with work boots on and I'm pretty sure they'd work loose eventually and fall off, especially with all the summer/winter heat cycling.
I'm keen to see if the metal brake pedal cover adds a bit of pedal feel or not, compared the standard issue rubber cover The only slight concern with metal pedals I have is slippage! I had metal pedals in my Golf and I came a cropper with wet shoes a few times |
danb19791956.50 |
06-03-2023, 04:45 AM | #6 | |
1957
Rep 2,135
Re the pedals; they're metal but very rubberised too so slipping won't be an issue
06-30-2023, 03:25 AM | #7 |
3105
Rep 7,034
Drives: 335xd Msport +
Just a suggestion, which may be too late given you’ve bought the kit already but may help others.
You can get slip on ones , whereby you pull/ slide off the original rubber covers and replace with the aluminium ones in the same way.
06-30-2023, 02:26 PM | #8 |
830
Rep 1,065
A bit late for me as I've ordered the oem ones
I don't mind a bit of drilling though. I take it the dead pedal one is stick on only? On the subject of pedals, is it just me or are they too far offset inboard? In my usual driving position which is most comfortable for pedal and steering wheel reach, I find I only use the furthest right corner of the brake pedal (auto). It feels unnatural to lift my foot up and down again square onto the brake pedal. I tend to do just slide my foot off the gas over to the brake, like most people I expect. To me at least, it seems like the pedals need to be a good few inches further to the right! Never had this (first world) 'problem' in VWs, so must be a RHD BMW thing. Anyway, as you were |
