Misfire
05-12-2023, 07:20 PM | #1 |
Rep 15
Drives: 2007 bmw 328i
Misfire
I have a 2007 328i. It started misfiring immediately when I turned on the car when I was leaving school. The oil pressure sensor also came on at the same time, anybody know what could cause this to happen. I know it was leaking oil as well, I know if it was just low on oil so I put some more oil in but it didn’t change anything.
The two codes are P0301-cylinder 1 misfire P0521-oil pressure sensor |
05-14-2023, 12:51 AM | #2 |
298
Rep 2,015
miss fire is not related to your oil.
Not sure if you can, or are mechanically inclined. but just swap the coil from 1 to 4.....see if the miss fire follows.. if the code stays on cyl 1, then swap spark plug to cly 3 or some other one. if the code follows, then it is sthe spark plug else it is something else like fuel mixture. |
