N54 Auto Launch
04-30-2023, 08:18 AM | #1 |
Rep 13
N54 Auto Launch
Hello, i got a Single turbo N54 with the auto transmission. ill be doing drag racing. The problem is, when i press the brake and the throttle, my RPMs only go to 2k, and my turbo needs around 3500 to spool, how can i increase that so my turbo is actually in boost when i launch the car?
05-01-2023, 06:50 AM | #2 | |
2002
Rep 3,731
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
05-02-2023, 02:05 PM | #4 |
2002
Rep 3,731
Google......
Here is the first link that popped up....many more to surf through. https://www.levelten.com/Level_10_Bm...g310-9000p.htm
05-02-2023, 11:24 PM | #5 | |
4277
Rep 9,209
05-03-2023, 04:37 PM | #6 |
2002
Rep 3,731
Yes, a 6HP28 would be the best idea...but then you will still need a high stall converter for it....and a good set of slicks if you want to actually put all the power to the ground 👍
