04-27-2023, 07:01 AM | #1 |
B58 Power
498
Rep 633
Drives: 05/2022 M340i xDrive Touring
G20 EU spec Welcome Light
Hi there,
as already discussed in other threads i had the opportunity to download the data of a G20 LCI EU spec. I already had the data of a G80 and G82 EU spec and will share them aswell. Some context for this. BMW seems to made some difference between the EU and some US spec car regarding the Welcome Light or headlight animation when unlocking. The G20 PreLCI can only control both DRLs as a pair while the G80 and G20 LCI can control them individually. This was a side effect of developing the turn signal into the tubes of the headlight instead of having a separate turn signal above the tubes. This side effect was used for the nice animation we know from the G20 LCI EU spec. Now comes the good news, it´s not hard coded into the software! You can code this with E-Sys. I´m not sure about Bimmercode or other solutions, as you need to paste the data into the FLM2 ECUs. 1. G20 PreLCI EU spec - Welcome Light View post on imgur.com Code:
Staging1_Data 01, 00, 0F, 32, 00, 32, 00, 19, 00, 19, 00, 19, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 05, 32, 00, 32, 00, 19, 00, 0C, 14, 3C, 43, 03, 00, 03, 3C, 2B, 3B, 14, 0C, 00, 04, 00, 03, 32, 00, 0C, 14, 3C, 2E, 05, 00, 06, 32, 2E, 32, 2E, 32, 2E, 3C, 2B, 3B, 14, 0C, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 Staging2_Data 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 2. G20 LCI EU spec - Welcome Light View post on imgur.com Code:
Staging1_Data 01, 00, 0F, 19, 00, 28, 00, 3C, 00, 3C, 00, 3C, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 0B, 5A, 00, 21, 1E, 05, 1E, 03, 64, 03, 1E, 0D, 1E, 03, 64, 03, 1E, 0A, 1E, 21, 64, 4B, 1E, 03, 00, 0B, 5A, 00, 21, 1E, 08, 1E, 03, 64, 03, 1E, 08, 1E, 03, 64, 03, 1E, 0D, 1E, 21, 64, 4B, 1E, 04, 00, 0B, 2D, 1E, 14, 1E, 08, 1E, 06, 1E, 09, 5F, 03, 62, 03, 64, 03, 62, 02, 60, 53, 00, 03, 00, 05, 00, 0A, 2D, 1E, 23, 1E, 06, 1E, 09, 5F, 03, 62, 03, 64, 03, 62, 02, 60, 4B, 00, 03, 00, 06, 00, 03, 41, 00, 32, 43, 80, 43, 07, 00, 03, 01, 43, 64, 43, 96, 00, 08, 00, 0B, 01, 00, 21, 1E, 05, 1E, 03, 64, 03, 1E, 0D, 1E, 03, 64, 03, 1E, 0A, 1E, 21, 64, 4B, 1E, 09, 00, 0B, 01, 00, 21, 1E, 08, 1E, 03, 64, 03, 1E, 08, 1E, 03, 64, 03, 1E, 0D, 1E, 21, 64, 4B, 1E, 0A, 00, 03, 01, 00, 32, 43, 80, 43, 0B, 00, 02, 01, 00, 05, 64, 0C, 00, 0B, 5A, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0D, 00, 0A, 5A, 00, 21, 1E, 03, 64, 03, 1E, 17 Staging2_Data 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 0E, 00, 0B, 01, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0F, 00, 0A, 01, 00, 21, 1E, 03, 64, 03, 1E, 17, 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 But this data should work for the G20 LCI US spec! I would highly appreciate if someone could provide me the original G20 LCI US spec data. 3. G80 EU spec - Welcome Light View post on imgur.com Code:
Staging1_Data 01, 00, 0F, 3C, 00, 3C, 00, 3C, 00, 3C, 00, 3C, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 15, 19, 00, 28, 00, 05, 00, 19, 0A, 05, 12, 05, 1C, 05, 2B, 05, 3A, 05, 4C, 05, 5B, 05, 64, 05, 64, 05, 59, 05, 4A, 05, 3F, 05, 3A, 05, 36, 05, 33, 05, 31, 04, 30, 04, 30, 03, 00, 15, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 19, 0A, 05, 17, 05, 2A, 05, 41, 05, 55, 05, 64, 05, 64, 05, 59, 05, 4A, 05, 3F, 05, 3A, 05, 36, 05, 33, 05, 31, 04, 30, 04, 30, 04, 00, 10, 19, 30, 32, 30, 0A, 37, 0A, 3C, 0A, 48, 08, 55, 08, 5E, 03, 63, 03, 64, 05, 64, 0A, 5F, 08, 4C, 08, 3A, 07, 28, 05, 19, 08, 00, 05, 00, 0E, 19, 30, 32, 30, 0A, 37, 0A, 3C, 0A, 48, 0A, 53, 05, 5E, 0A, 64, 0F, 62, 0A, 4B, 0A, 3A, 09, 26, 07, 14, 07, 00, 06, 00, 02, 96, 00, 55, 64, 07, 00, 08, 3C, 64, 3C, 64, 0A, 64, 2D, 63, 1C, 5A, 19, 4B, 23, 19, 05, 00, 08, 00, 13, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 05, 00, 19, 05, 05, 14, 05, 3A, 05, 55, 05, 64, 05, 64, 05, 5A, 05, 3C, 05, 1E, 05, 0F, 05, 05 Staging2_Data 05, 02, 05, 00, 09, 00, 13, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 05, 00, 19, 05, 05, 14, 05, 3A, 05, 55, 05, 64, 05, 64, 05, 5A, 05, 3C, 05, 1E, 05, 0F, 05, 05, 05, 02, 05, 00, 0A, 00, 10, 32, 00, 1E, 14, 0F, 28, 08, 3C, 09, 4D, 07, 5A, 03, 62, 03, 64, 05, 64, 08, 61, 05, 5A, 08, 4E, 07, 3B, 07, 27, 06, 14, 05, 00, 0B, 00, 0E, 32, 00, 1E, 14, 0F, 28, 08, 3C, 09, 4D, 07, 5A, 03, 62, 03, 64, 05, 64, 08, 64, 14, 50, 12, 28, 06, 14, 05, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 View post on imgur.com Code:
Staging1_Data 01, 00, 0F, 3C, 00, 3C, 00, 3C, 00, 3C, 00, 3C, 00, 3F, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 64, 32, 32, 32, 00, 02, 00, 15, 19, 00, 28, 00, 05, 00, 19, 0A, 05, 12, 05, 1C, 05, 2B, 05, 3A, 05, 4C, 05, 5B, 05, 64, 05, 64, 05, 59, 05, 4A, 05, 3F, 05, 3A, 05, 36, 05, 33, 05, 31, 04, 30, 04, 30, 03, 00, 15, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 19, 0A, 05, 17, 05, 2A, 05, 41, 05, 55, 05, 64, 05, 64, 05, 59, 05, 4A, 05, 3F, 05, 3A, 05, 36, 05, 33, 05, 31, 04, 30, 04, 30, 04, 00, 10, 19, 30, 32, 30, 0A, 37, 0A, 3C, 0A, 48, 08, 55, 08, 5E, 03, 63, 03, 64, 05, 64, 0A, 5F, 08, 4C, 08, 3A, 07, 28, 05, 19, 08, 00, 05, 00, 0E, 19, 30, 32, 30, 0A, 37, 0A, 3C, 0A, 48, 0A, 53, 05, 5E, 0A, 64, 0F, 62, 0A, 4B, 0A, 3A, 09, 26, 07, 14, 07, 00, 06, 00, 02, 96, 00, 55, 64, 07, 00, 08, 3C, 64, 3C, 64, 0A, 64, 2D, 63, 1C, 5A, 19, 4B, 23, 19, 05, 00, 08, 00, 13, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 05, 00, 19, 05, 05, 14, 05, 3A, 05, 55, 05, 64, 05, 64, 05, 5A, 05, 3C, 05, 1E, 05, 0F, 05, 05 Staging2_Data 05, 02, 05, 00, 09, 00, 13, 19, 00, 28, 00, 05, 00, 05, 00, 05, 00, 05, 00, 19, 05, 05, 14, 05, 3A, 05, 55, 05, 64, 05, 64, 05, 5A, 05, 3C, 05, 1E, 05, 0F, 05, 05, 05, 02, 05, 00, 0A, 00, 10, 32, 00, 1E, 14, 0F, 28, 08, 3C, 09, 4D, 07, 5A, 03, 62, 03, 64, 05, 64, 08, 61, 05, 5A, 08, 4E, 07, 3B, 07, 27, 06, 14, 05, 00, 0B, 00, 0E, 32, 00, 1E, 14, 0F, 28, 08, 3C, 09, 4D, 07, 5A, 03, 62, 03, 64, 05, 64, 08, 64, 14, 50, 12, 28, 06, 14, 05, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 This would be another option for the G20 LCI US spec drivers. The next step would be an analyses of the data and how the animation is made. Maybe we could write our own headlight animations? kind regards Michael
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
RCtennis3811476.50 EXE462104.50 UnknownBeing132.00 C3Z_330i15.00 prjkthack70.50 panki_86137.50 donewithit23.00 AlpineAl2783.00 akataka23.00 Rawhide365.50 |
04-27-2023, 08:54 AM | #3 |
72
Rep 177
Any idea what the difference is between Staging1_Data and Staging2_Data? Converted the "BMW G21 PreLCI Welcome Light" to decimal to see if anyone can figure out any correlation to the animation. I'm assuming it's some variation to determine brightness and timing.
Code:
1, 0, 15, 50, 0, 50, 0, 25, 0, 25, 0, 25, 0, 63, 100, 50, 100, 50, 100, 50, 100, 50, 100, 50, 100, 50, 100, 50, 100, 50, 50, 50, 0, 2, 0, 5, 50, 0, 50, 0, 25, 0, 12, 20, 60, 67, 3, 0, 3, 60, 43, 59, 20, 12, 0, 4, 0, 3, 50, 0, 12, 20, 60, 46, 5, 0, 6, 50, 46, 50, 46, 50, 46, 60, 43, 59, 20, 12, 0, 0, |
04-27-2023, 08:58 AM | #4 |
182
Rep 308
This is amazing, MichaelNRW ! So glad you were able to figure this out so quickly!
So if you had a non-LCI G80 M3 Comp OR an LCI G20 3 Series, would the G20 LCI animation effect work on both just like this video, with the shift back and forth? (Apologies for the annoying music, not my video) https://www.youtube.com/shorts/cfUSGyggj_w |
04-27-2023, 09:15 AM | #5 | |
B58 Power
498
Rep 633
I currently don´t have any G80 near me to test this out :-)
04-27-2023, 09:37 AM | #6 | ||
B58 Power
498
Rep 633
That´s just two data fields because one wasn´t enough :-) They´re both for the welcome light animation. While the G20 PreLCI is pretty short, the G20 LCI and G80 are very long and just need more space. Quote:
But they´re not the same length... I´m still trying to figure out what the sequence contains. There needs to be some type of mapping to the actual lights of the headlights. Here´s the mapping of IDs to names. 00 = n/a 01 = LB1 02 = LB2 03 = LB3 04 = LB4 05 = HB1 06 = HB2 07 = HB3 08 = DRL1 09 = DRL2 10 = DRL3 11 = CL1 12 = CL2 13 = CL3 14 = SML1 15 = SML2 16 = SML3 17 = FRAZ1 18 = ZFL_LSR1 19 = IZ1 And here are the mappings from the different cars. G20 PreLCI Code:
LM01_Name = 06 = Highbeam2 LM02_Name = 02 = Lowbeam2 LM03_Name = 00 LM04_Name = 03 = Lowbeam3 LM05_Name = 0A = DRL3 LM06_Name = 04 = Lowbeam4 LM07_Name = 02 = Lowbeam2 LM08_Name = 03 = Lowneam3 LM09_Name = 07 = Highbeam3 LM10_Name = 01 = Lowbeam1 LM11_Name = 09 = DRL2 LM12_Name = 04 = Lowbeam4 LM13_Name = 00 LM14_Name = 00 LM15_Name = 00 Code:
LM01_Name = 00 LM02_Name = 03 = Lowbeam3 LM03_Name = 0A = DRL3 LM04_Name = 07 = Highbeam3 LM05_Name = 04 = Lowbeam4 LM06_Name = 03 = Lowbeam3 LM07_Name = 02 = Lowbeam2 LM08_Name = 06 = Highbeam2 LM09_Name = 03 = Lowbeam3 LM10_Name = 02 = Lowbeam2 LM11_Name = 00 LM12_Name = 00 LM13_Name = 04 = Lowbeam4 LM14_Name = 00 LM15_Name = 00 LM16_Name = 00 LM17_Name = 00 Code:
LM01_Name = 00 LM02_Name = 02 = Lowbeam2 LM03_Name = 00 LM04_Name = 02 = Lowbeam2 LM05_Name = 04 = Lowbeam4 LM06_Name = 04 = Lowbeam4 LM07_Name = 06 = Highbeam2 LM08_Name = 03 = Lowbeam3 LM09_Name = 03 = Lowbeam3 LM10_Name = 07 = Highbeam3 LM11_Name = 0A = DRL3 LM12_Name = 09 = DRL2 LM13_Name = 04 = Lowbeam4 LM14_Name = 04 = Lowbeam4 LM15_Name = 00 LM16_Name = 00 LM17_Name = 00
EXE462104.50 |
04-28-2023, 12:09 PM | #7 |
Rep 16
its work asser well on G80, test at the moment, I would put a video on the occasions! On the other hand you have all the growth lights that come on unlocking, me never, an idea?
04-29-2023, 03:58 AM | #9 | |
B58 Power
498
Rep 633
Have you checked the settings in your iDrive? I´m not sure if there´s a setting for the Welcome Light. Another idea would be it´s not dark enough.
04-29-2023, 07:23 AM | #10 |
Rep 16
Yes in the iDrive everything is good, impossible to understand why the lasers do not turn on... And in the BDC or FLM2, nothing that corresponds to the ignition of the laser in welcome light ...
Even in my garage where it is dark night, does not light .. |
04-29-2023, 08:32 AM | #11 | |
B58 Power
498
Rep 633
Do other cars made for Belguim have Welcome Light or is there some law that doesn´t allow this?
05-08-2023, 12:58 AM | #13 |
Rep 29
Thank you for sharing! Can you check if the Staging 1 and 2 data are different between left and right FLM modules? I copied the EU G20 LCI staging data into both FLM and both front lights 'flash' at the same time rather than 'sweeping' from left to right. I suspect the data in the left and right FLM modules are timed differently to give the sweeping effect.
Here is the US G20 LCI staging data which is identical between both modules. Code:
Staging1_Data 01,00,0F,19,00,28,00,3C,00,3C,00,3C,00,3F,64,32,64,32,64,32,64,32,64,32,64,32,64,32,64,32,32,32,00,02,00,04,41,00,1E,1E,32,64,46,1E,03,00,04,53,00,19,1E,26,64,46,1E,04,00,0B,2D,1E,14,1E,08,1E,06,1E,09,5F,03,62,03,64,03,62,02,60,53,00,03,00,05,00,0A,2D,1E,23,1E,06,1E,09,5F,03,62,03,64,03,62,02,60,4B,00,03,00,06,00,03,41,00,32,43,64,43,07,00,03,01,43,64,43,51,00,08,00,04,01,00,1E,1E,32,64,46,1E,09,00,04,12,00,19,1E,26,64,46,1E,0A,00,03,01,00,32,43,64,43,0B,00,06,19,00,28,00,32,00,32,00,32,64,05,64,0C,00,04,32,00,32,00,32,64,05,64,0D,00,03,01,64,64,64,64,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00 Staging2_Data 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
2023 M340i / 2016 X6 M / 2010 M5
05-08-2023, 02:42 AM | #14 | ||
B58 Power
498
Rep 633
I´ll try to get in contact with the owner and meet him again. Quote:
Entwicklungsbaureihe = G021 FAVersion = 3 Typschlüssel = 81FY Zeitkriterium = 0722
yamanote10.00 |
05-08-2023, 04:21 AM | #15 |
B58 Power
498
Rep 633
I tried to calculate the coding by EsysUltra calculates the same values for both FLM2 ECUs.
I´m near the owner next tuesday and maybe get the chance to backup the coding again.
05-09-2023, 03:11 AM | #16 |
Rep 29
Played around with this earlier today with the ECE typschlussel, 41FF for LCI M340iX sedan according to ISTA+. You are right - the cafd is the same between both FLM modules and there does not appear to be any difference in the coding between them.
Coding the FLM modules with ECE type triggers lowbeam errors unlike pre-LCI. As mentioned earlier using the Staging data from the original post makes both lights do the flashing animation concurrently rather than 'sweeping' from side to side. The goodbye/lock animation doesn't change from the US version btw, not sure if this is correct or if there is another line that needs to be changed. The amber sidemarkers flicker during the animation as well. I guess it would be better if I can figure out how to turn them off. Based on the coding it looks like it might be LM01 or LM11? I've attached the ncd compare, maybe you can make better sense of it than me. NCD1 is coding based on US FA (with 5AP deleted), NCD2 is ECE.
05-09-2023, 10:23 AM | #17 | |
B58 Power
498
Rep 633
Do both tubes flash at the same time like mine on the PreLCI? I´ll have a look at the data, thanks for that.
05-09-2023, 04:43 PM | #18 | |
Rep 29
View post on imgur.com Both tubes are properly individually addressed but the animation goes from 'inside out' rather than 'left to right' if that makes sense. https://youtube.com/shorts/Hriq8X5qQMk?feature=share
05-12-2023, 08:28 PM | #20 | |
182
Rep 308
05-13-2023, 02:37 AM | #21 |
B58 Power
498
Rep 633
I‘ll meet the G20 LCI owner on tuesday and share the ncd afterwards.
Let‘s see if it‘s the same for both sides or if there‘s another value that controls the animation timing. |
05-16-2023, 09:57 AM | #22 |
B58 Power
498
Rep 633
I´ve got bad news...
I´ve met the G20 LCI owner again and read out the coding data of both FLM2 one by one. They´re the same! So there needs to be something else that tells the headlights which side starts the animation.
razzle4544.50 |
