I keep getting misunderstood
05-17-2006, 09:37 PM | #1 |
Rep 5
Does anyone know if the speakers by back window on shelf are 6 1/2s ?
Not subs and not speakers in door or under seats... Also - if I add amp ( not sub amp) and change stock speakers, is that a big job to wire new speakers ? Has anyone out there put in a new head unit ? Crutchfield does not have anything yet on this car... |
05-18-2006, 09:43 AM | #2 | |
72
Rep 671
the rears on the basic stereo setup are actually 3" with a 1" tweeter mounted on a plate right next to them. yes you can swap the deck, and that with an amp install is kinda a big deal
"tell me what you don't like about yourself..." |
05-18-2006, 12:31 PM | #3 |
18
Rep 370
Drives: E90 325xi
a new amp shouldn't be too difficult. just bypass the factory one... it's easily accessible in the trunk. if you use the stock wiring for new speakers, it shouldn't hurt too bad.
05-18-2006, 03:24 PM | #4 | |
Enthusiast
468
Rep 1,791
Drives: F87 M2 / F31 330d
Garage List 2004 E46 BMW M3 [0.00]
2017 F87 BMW M2 [10.00] 2013 F31 330d Touring [9.50] 2009 E89 Z4 Sdrive 30i [9.00] 1989 E30 320is 2-door [10.00] 1986 E28 M535i [9.00] |
Midrange units in doors and on the back shelf are 4" (100 mm) on all speaker setups. Read here: http://www.e90post.com/forums/showthread.php?t=18287 |
05-18-2006, 10:12 PM | #6 |
16
Rep 80
I've read elsewhere that rewiring the speakers is nearly impossible. I'd stick with replacing the speakers and the amp.
Speaking of which...what are the connectors like on the stock amp (325 without Logic7)? Would you need some pinouts to know what you are doing? And where would you get them? |
05-18-2006, 10:12 PM | #7 | |
13
Rep 142
SmellyGas |
05-19-2006, 01:42 AM | #8 | |
Enthusiast
468
Rep 1,791
05-20-2006, 10:56 AM | #10 |
Enthusiast
468
Rep 1,791
German Member 'Tierfreund' knows a lot about that, he swapped his headunit.
There's a thread about it, i'll look it up. Edit: Here's a thread with lots of information. Try PM tierfreund. |
