BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Euro Spec Anti-Dazzle Headlight Coding?
      02-27-2023, 06:18 PM   #1
GriggsyG22
83
Drives: 2023 BSM M5C w/ 813m's
Does anyone know if this is something that bimmercode can code in with the F90 LCI or is that not a possibility with this model? Just been looking around trying to find all the helpful lil things I can/should be coding in. I've only done the B&W Sound Profiles upgrade and the replaced the Bronze Ambient Lighting for Magenta so far.
      02-27-2023, 06:35 PM   #2
ResIpsaLoquitur
ResIpsaLoquitur's Avatar
No_Country
4092
Drives: 2022 M5C
Checking the F90 available options to be coded on BimmerCode, there is no listing for this feature.
I’ve always been curious about the BE sound profiles. Does your HK sound better after coding it?
Not a BMW guy...but certainly an M5 guy.
      02-27-2023, 07:19 PM   #3
GriggsyG22
83
I'll be honest. I'm sure if it actually made anything necessarily sound better. It allowed for surround sound control and the profiles do give different sound dynamics but I wouldn't say anything necessarily sounds better. I may end up having the subs in my Jeep swapped over to the M5 however.
Buddy knows how to do that stuff and says it would be about $200 in parts and about an hour worth of work. He'd have to throw the subs in, tap the new amp into the battery, then run an LOC (line output convertor) into the OEM amp to take the signal from it and that in return would be ran into the aftermarket amp and then run the aftermarket amp to the subs. Stock speakers would still run on OEM amp, subs would run off of the aftermarket.
      02-27-2023, 07:39 PM   #4
ResIpsaLoquitur
No_Country
4092
Drives: 2022 M5C
Thanks for your input.
I’ve seen a few guys do that where they’ll put them in the trunk and then have to open the pass through to actually allow any bass through due to the cabin’s being significantly insulated (hence the ASD). I’d hate to have to deal with all that.
Because of a good tip by RalphT5, I’m looking at just trying to swap to an AudiotecFischer MatchUp amp and trying that route to get some better bass in the car (in conjunction with swapped out under seat subs).
RalphT5255.50
      02-27-2023, 08:05 PM   #5
GriggsyG22
83
How actually does one "open the pass through" ??
      02-27-2023, 09:53 PM   #6
ResIpsaLoquitur
No_Country
4092
Drives: 2022 M5C
So I’ve ever actually only done this once, but the releases are in the flat panel that is in the trunk just below the bottom of the rear glass. Since it’s a 40/20/40 split, I can’t remember if it’s the left one or the right one that opens the pass through. But they can all (or one/two) remain open independently. Open them all using both levers, then close the two 40 splits.
Not the route I’d recommend going if you’re thinking of putting an enclosure back there, though.
Just my $0.02.
      02-28-2023, 03:16 AM   #7
TheNine90
578
Drives: bmw
For bimmercode its a bit complicated. It better to use esys since you have you have to modify the FA and code the modules.
      02-28-2023, 10:12 PM   #8
CrashCade
112
Drives: '19 M5 Comp,
ProTools is setup to make this straight forward. If you cannot figure it out, their customer support is amazing!
      03-02-2023, 02:09 AM   #9
micvite
1540
Drives: 2009 mazda RX8
It doesn't work 100%, I'd say it's like 80% there though doing it that way... having a coder do it got it to like 90% but still was having issues on mine. Ymmv though... when I go to Germany in a few days I plan to "rip" the coding straight out of a car instead of generate it with esys to see if there's any differences.
      03-05-2023, 09:40 PM   #10
CrashCade
112
Mine seems to function 100% how it should using ProTools. Maybe I was fortunate.
      03-06-2023, 02:06 PM   #11
ResIpsaLoquitur
No_Country
4092
Drives: 2022 M5C
Just my $0.02.
EDIT — There is also a latch under the rear seat center headrest that releases the pass through independent of the folding seats/trunk latch.
      03-07-2023, 03:46 PM   #12
adeuel
317
Drives: 2021 Oxford Green M5C
I had my LCI headlights coded remotely, including the Euro spec auto high beams, in under 20 minutes. Works flawlessly. Search and contact "Almaretto" on the forums.
Current: 2021 Oxford Green over Caramel M5C
2022 Ford Mustang Mach 1 : 2021 Yukon Denali : 2011 Ti Silver 128i 6MT, Koral
Gone: 2021 Carbon Black X7 M50i : 2018 SG M5
2016 Med Blue 650ix GC : 2008 BSM 535i 6MT
1999 Jet Black 528i
Appreciate 3
      03-28-2023, 07:53 PM   #13
RalphT5
RalphT5's Avatar
256
Drives: 2023 F90
  [0.00]
Thanks!! Will look into this after my software update.
2023 F90
m5post
