02-19-2023, 08:26 AM | #1 |
Rep 5
CarPlay Stretched Screen Issues
I am fairly new to BMW as a whole so I apologize in advance if I lack any knowledge. So I used Bimmer Tech’s VIN decoder to find out what head unit I had since my car had the 6.5” display with no navigation. I found out I had ENAVEVO even though Bimmer Code was showing NBTevo. So I got CarPlay coded through Bimmer Remote to get it enabled. I then used Bimmer Code to enable fullscreen Apple CarPlay. Now the screen is stretched and it’s kind of bugging me.
I checked Bimmer Code to make sure these were enabled 3001 EXBOX > DISPLAY_VARIANTE = breites_display 3005 APIX_CID > CID_DISPLAY_SIZE = 8.8 3005 APIX_CID > CID_DISPLAY_RES = 1280x480 3006 NAVIGATION > DISPLAY_SIZE_RESOLUTION > 8.8=1280x480 3005 CARPLAY_FULLSCREEN > AKTIV Is there anything that I am missing? My last 7 digits to my VIN are K384615. |
03-18-2023, 12:02 PM | #3 |
8274
Rep 16,138
Assuming it works like a computer screen you probably need to use different resolution. Finding the right one is probably a matter of trial and error.
03-20-2023, 03:10 PM | #4 | |
1797
Rep 3,062
You need firmware update to get it working properly - its not the coding problem, software is too old for properly working fullscreen. PM sent.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
03-21-2023, 11:13 AM | #5 |
22
Rep 43
What would be too old software and what would be up to date version? I would assume that it would support full screen as it has the parameter for coding.
Mine is stretched in widescreen and it’s also a little bit stretched vertically in split screen mode but looks ok, widescreen is like setting 4:3 picture on 16:9 to fill screen. 2018 car, entryEvo with 8.8” screen retrofit |
