2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media Missfires in my mom car yall 2011 550i
      01-21-2023, 09:16 PM   #1
Flatrabbit777
Drives: 2011 BMW 550i
Ill try to get straight to the point. please excuse my southern slang.
This was always my moms dream car and she could finally afford it over a decade later. She doesnt need the car back working in a hurry but damn sure aint got the money for the shop.
she bought the car and a week later multiple misfires. I aint a BMW mechanic but I have turned some wrenches before. I started with the obvious the battery seeing how BMW go buckwild with out a good battery. Battery is registers same ah and all that. Changed all the plugs and coil packs and fixed a vacuum leak. it idles and will rev up and not throw a code but if you drive it and give it some gas it starts rattling like a bag of cans.
multiple misfires on 5,6,8 read the codes with ista. I'm thinking 3 injectors wouldnt have went bad at the same time so Im thinking I got a vacuum leak on that side or the fuel pump on that side is screwed. if anyone can tell me if im on the right track or any suggestions Id appreciat it.
Thanks yall
      01-25-2023, 07:07 PM   #2
550bye
550bye's Avatar
1390
Drives: 2011 550i
2011 BMW 550i  [5.67]
Flatrabbit777 you would have to post some faults because it could be a handful or two of things. I have had those exact symptoms from 1) intake being loose, 2) faulty injectors, 3) CCV broke. So it could still be a long list of things. I personally just wouldn’t troubleshoot based on symptoms is what I’m getting at.
Three injectors could definitely have gone bad at the same time, I had 3 go bad at once on the same bank. Dealership told me it was the HPFP but it’s still running strong 4 years later, the injectors I was forced to replace. Good luck
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
5post
