front suspension camber adjustment on 335i
01-06-2009, 08:53 PM | #1 |
54
Rep 213
Suspension question, (335i sdn E90) Running 19 inch CSLs and BMW performance springs/struts with upgraded sways. Is it better to have as much negative camber in the front as possible for better turn-in/handling? Tire wear is not an issue for me. I know the alignment pin in the top of the strut can be drilled out which allows for a small bit of camber adjustment.
01-07-2009, 01:40 PM | #2 |
Moderator
618
Rep 10,855
Have you tried the M3 control arms yet? That adds some negative camber.
Your set-up should fit the driving that you do. If you are focussed on autocross, then you may want to go further down the path of negative camber, and a huge front sway bar. If you are interested in high speed highway performance and rational DD, then you need a different set-up. One of the keys to getting good performance involves reducing the flex in the bushings that allow for movement and changes in wheel angles. Hence the interest in the M3 suspension parts.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-14-2009, 11:37 PM | #3 | |
Supreme Allied Commander
3862
Rep 54,424
Drives: F80 M3
01-15-2009, 07:30 PM | #4 | |
Riding the knock sensor
2371
Rep 1,596
Drives: 21 X5MC | 23 M4CSL
+1 on the M3 bits to add a litle camber.
01-16-2009, 12:52 AM | #6 |
3862
Rep 54,424
Drives: F80 M3
