Winter 91 or higher octane?
01-06-2009, 08:56 AM | #1 |
Rep 130
I just took a trip to US, Northern Michigan
(same temperatures as in Ontario) and for the lack of 91 octane on most of the stations i was pumping 94 octane. I have a 2008 328i, and i noticed 10-15% better millage? Should i be running higher octane gas in cold winters of Canada? |
01-06-2009, 09:20 AM | #2 |
47
Rep 821
Somebody correct me if I'm wrong but the higher the octane, there is less possibility of the fuel freezes. However isnt the highest we have in Canada (at least Toronto) 91 Octane?
01-06-2009, 09:42 AM | #4 | |
27
Rep 959
10-15% seems like too much of a difference. As far as fuel freezing, just how cold does it get? My car has no problem starting at -20F (-29C) in the winters.
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC Last edited by gos; 01-06-2009 at 09:43 AM.. Reason: added celsius |
01-06-2009, 09:52 AM | #6 |
Rep 130
Starting is no problems here (gets down to -30 C all the time)
i just want an opinion on the advantages or disadvantages of using higher octane fuel in 3 series BMW recommends 91 octane as the lowest grade but does that mean that prolonged usage of 94 octane can damage the engine. or is it just the higher cost issue? |
01-06-2009, 10:10 AM | #7 | |
47
Rep 821
01-06-2009, 10:45 AM | #8 |
Rep 130
Sorry man but your octane rating are different then NA
87 octane fuel, the "regular" gasoline in the US and Canada, is 91–92 in Europe European pumps deliver 95 (RON) as "unleaded", equivalent to 90–91 US read this http://en.wikipedia.org/wiki/Octane_rating |
01-06-2009, 11:06 AM | #9 | |
47
Rep 821
01-06-2009, 02:49 PM | #10 |
just another bmw douche bag
195
Rep 3,640
This is not necessarily true. Higher octane can allow the engine to make more power if it is tuned for higher octane. You have to have the engine put in more timing and fuel (or boost on a turbo car) to take advantage of the octane.
Usually cars that are tuned to a higher octane, will pull out timing (or boost) if the computer senses knocking or 'ping' to avoid damaging the motor. So unless your car isn't running 100% on the gas you are currently putting in, higher octane won't give you more power. just dumping in 100 octane won't give you any power (unless there was a problem with the gas you were previously running). but add timing, fuel, and/or more boost for it, and you'll be able to make more power than with regular pump grade gas. If you don't do anything, it shouldn't hurt (except in your wallet), as long as you stick with unleaded fuels. |
01-06-2009, 02:54 PM | #12 |
167
Rep 7,433
you guys suck for being able to get 94 octane. here in norcal it's hard to find anything over 91
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-06-2009, 03:10 PM | #14 | |
15
Rep 701
+1
good descripton Mikey. Higher octane (above what the car is tuned for) isn't going to give you better gas milage, especially in the winter (detonation is more of a problem in hot humid summer months). Also, sunco uses a lot of ethanol, which is killed my gas milage (5 MPG drop). I had a sudden and noticable drop in MPG when I put that ethanol blend crap in my tank. Quote:
_________________________________________________
01-07-2009, 07:41 AM | #15 |
Rep 130
01-07-2009, 08:50 AM | #16 | ||
341
Rep 16,407
+1 on the great description and the ethanol side. More and more stations are starting to boost the octane numbers by adding ethanol to the mix. Basically turning 91 into 93, 94 by adding ethanol. While it does give you a power boost, you pay for it via lower MPG. |
01-07-2009, 03:39 PM | #17 |
15
Rep 701
Actually a gallon of Ethanol has lower energy output than a gallon of gas. Thus, it has less power, and less MPG.
A gallon of Regular and a gallon of 100 octane have the same energy output, which is why you will not get more power or more MPG with high octane fuel, as long as you are meeting your car's minimum requirements.
01-07-2009, 05:47 PM | #19 |
130
Rep 5,040
I stay away from sunoco and ultra 94. It has 10% ethonol, which is rumored to damage the fuel pump and results in lower gas milage (on my 335 at least). I stick to shell vpower (91 and no ethonol).
01-07-2009, 09:26 PM | #20 | |
42
Rep 403
Drives: 2007 BMW 328i
Ethanol over 10% like the gas in the US that is 85% Ethanol will fry your motor. The BMW manual says the engine is OK to use up to 10% ethanol anyways. |
01-07-2009, 10:39 PM | #21 | |
152
Rep 3,983
Around 40k and been using 94 at least half the time.. no issues. |
01-07-2009, 11:53 PM | #22 |
Trance Life
315
Rep 4,706
I don't believe higher octane would have any significant effect in lowering the freezing point of the gasoline.
This is kind of like the nitrogen-filled tires myth. Uneducated people will buy into it. |
