12-19-2022, 03:46 PM | #1 |
20
Rep 83
serpentine belt idler tensioner pulley
Hey guys, ive been noticing that my car has been making a weird noise around 800-1000 rpm. I figured it might be a belt issue or something, and saw today that my idler pulley seems to be vibrating. sound is only coming from those specific rpms 800-1000, making like a krrrrrrrrrrrrrr noise or like if something was grinding noise. noticed that my idle has been a little funky lately also, and i figured maybe it was related to this or something. sometimes my rpms jump from 600 to 800 then back down after a blip in throttle. looking to replace the tensioner, anyone know if this will fix my issues?
youtube video of my tensioner pully: https://www.youtube.com/shorts/0RCg7TqWzqw |
12-19-2022, 04:16 PM | #2 |
4374
Rep 7,624
Some amount of jiggle is unavoidable. However if you are over 60k or so miles its probably worth getting the kit with the belt from FCP and swapping it out preventatively. Mine looked similar and BMW replaced it under CPO warranty.
Having said that it would not affect idle. |
12-19-2022, 05:59 PM | #3 | |
20
Rep 83
12-19-2022, 06:29 PM | #4 | |
20
Rep 83
12-19-2022, 06:46 PM | #5 |
4374
Rep 7,624
Changes in idle based on AC load etc are normal, but fluctuations/bouncing up and down for no reason are not. So it just depends on what you are experiencing. Sounds like doing the belt/tensioner is not a bad idea, and see if it solves the problem.
12-20-2022, 01:51 PM | #6 | |
20
Rep 83
12-20-2022, 02:38 PM | #7 |
4374
Rep 7,624
Howl and idle issues can be signs of the VC leak IIRC. There are some similar threads on it where people think its their belt/tensioner and it ends up being the VC and howling air sound.
12-20-2022, 04:22 PM | #8 |
20
Rep 83
i just fixed a boost leak today, and my car seems to be idling fine now! when installing the intake i had to plug the extra hole near the maf censor on the cts turbo intake. i capped it but i never put a hose clamp on it. got one today, car feels so much better, and pulls a lot harder as well. the howling sound is still there tho. whats strange to me is that it only makes the howling sound around the 1k rpm and never above it or below it.
12-22-2022, 07:05 PM | #9 |
20
Rep 83
found this video: definetly not experinecing this form of sound, i think its most noticeable on the inside of the car, took it to a mechanic hood open and he couldn't really locate the issue aside from the pulley looking loose and it only being on throttle at 1000 rpm then goes away instantly after going over or going under.
12-23-2022, 06:33 AM | #10 |
3609
Rep 10,373
Typically you'll hear a rattling sound which will increase with engine speed. This is because the grease around the bearings of the pulley has dried out. Belt tensioners will have a little wobble. It's never dead still. Never.
Hearing a chirp can be another sign of a bad pulley or tensioner. Try searching some YT videos.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
Burnout27.00 |
01-08-2023, 09:07 PM | #11 | |
20
Rep 83
F32Fleet3609.00 |
