11-30-2022, 06:47 PM | #1 |
18
Rep 45
Drives: 2022 X5 XDrive45e
Preconditioning - Unreliable App
Is there any way to precondition my 45e besides using the MyBMW App on my phone? I ask because it seems like every other time I want to use the App the servers are down and can't send the request to my vehicle.
Overall, I'm over the moon with this car. In this one aspect, however, it feels like a step backward. We got buried with snow overnight and now I have to go sit in the car to precondition it while my wife, with her much less expensive vehicle, simply remote starts and waits in the house for it to warm up. I hope I'm missing something and there's a better way. |
11-30-2022, 07:29 PM | #2 | |
997
Rep 1,267
11-30-2022, 07:37 PM | #3 |
3214
Rep 6,885
Is the server, or is it the cellular connection?
A nice addition might be to put a WiFi client in the vehicle that could be used when the cellular was marginal. It would let it also get map and other firmware updates directly, rather than through the phone as is done today on OTA updates. |
11-30-2022, 10:57 PM | #4 |
200
Rep 225
You know you can also use (or set) a button on your vehicle key for that, right (if your vehicle is within the reach, of course)? Other than that I don't think there are any ways. It's either the app, the key or preprogrammed preconditioning which you can set from the vehicle before you leave it.
11-30-2022, 10:58 PM | #5 |
208
Rep 937
Drives: 2021 BMW X5 40i
If you are close by you can press the lock button on your key 3 times and it should start
| 2021 X5 xDrive 40i | Dravit Grey
Prev: Infiniti G35x --> e92 335i xDrive--> F30 335i M Performance Edition --> Audi S4 --> Audi S5 |
FiatLux11.50 |
11-30-2022, 11:54 PM | #7 |
18
Rep 45
I'll have to look into these suggestions, but, as far as I'm aware, the 45e is very different in this regard. For instance, the preconditioning happens from the battery system and not from the engine. So, to heat or cool the car you don't start the engine at all. And, as far as I know there is no way to remote start the engine.
Additionally, I looked in the menu of the car and found the place to do something with the key fob and there is no option to assign a button or anything to do with preconditioning... just several options for the back trunk lids, top and bottom. I can assign preconditioning to start on a schedule, but I don't have a regular schedule so that's not useful. When the app is working and can communicate with the car, life is good. Right now, however, the last status update I have from the car is the afternoon on the 29th. When the app is working, I always get an alert when I plug the car in and when it's done charging, so I know something is wonky. |
12-01-2022, 12:20 AM | #8 |
3214
Rep 6,885
Try resetting iDrive by holding down the volume button (about 30-seconds) until it reboots and see what happens. Just like your computer once in a while needs a reboot, your X5 can benefit from one as well.
12-01-2022, 04:57 AM | #9 | |
4727
Rep 8,803
Drives: eVeRyOnE mAD!
the OP already mentioned that scheduled preconditioning won't help him because his schedule isn't regular. |
12-01-2022, 04:59 AM | #10 | |
4727
Rep 8,803
SomeClown18.00 |
12-01-2022, 05:16 AM | #11 |
18
Rep 70
My app has been wonky lately too. Took me forever to finally get a change to my climate schedule to the car the other day. The app gives no indication there is a "server" issue, but I'd have to believe that would be the only explanation as I had a strong cell signal and the car was 30 feet from me.
12-01-2022, 05:43 AM | #12 | |
4727
Rep 8,803
can try: telematics reboot update apps and services double check Data Privacy settings restart phone logout, login MyBMW app |
12-01-2022, 09:28 AM | #14 |
4727
Rep 8,803
personally, i would love to be able to program preconditioning on my fob. do you use it often?
12-01-2022, 09:56 AM | #15 |
469
Rep 804
I didn't know the 45e doesn't do engine start. Does preconditioning without engine on even cool/heat the car up enough? On a different note, the GLEs do not have that feature to start from fob and if started with app, the car will shut off when door is opened. Interesting enough, their owners don't seem to mind at all.
Hope the OP gets it ironed out. I've never had issue with the app or fob remote start. |
12-01-2022, 10:02 AM | #16 | |
4727
Rep 8,803
12-01-2022, 11:32 AM | #17 |
183
Rep 261
It's sub-optimal because you have to go out into cold, but while my BMW app on my phone was down for three weeks, I activated pre-conditioning by the touch screen in the car.
12-01-2022, 11:46 AM | #18 | |
18
Rep 45
Thanks for the suggestions. I'll keep poking at it. |
nZtiZia4726.50 |
12-01-2022, 12:20 PM | #19 |
200
Rep 225
LOL. Not at all. I have the schedule set for the working days and use the app in all other cases. My problem with the button on the remote is that it doesn't give you any feedback. You assume it works. I tried a few times and it worked but don't have a real case for using it.
nZtiZia4726.50 |
12-01-2022, 12:32 PM | #20 |
208
Rep 937
Interesting didn't know it was different for ICE vs PHEV
nZtiZia4726.50 |
12-01-2022, 12:36 PM | #21 |
4727
Rep 8,803
preconditioning has some advantages:
- some countries forbid engine idling, so preconditioning allows PHEV/EV owners to heat/cool the interior in those countries since it doesn't require the engine to run. - it can also be done in enclosed spaces without fear of CO buildup. - it runs for 30 mins vs Remote Start's 15-minute run time. AFAIK, it doesn't have the '3 strikes and you're out' stipulation that RS does, either |
mad villain207.50 FiatLux11.50 |
Tags |
app, mybmp, precondition |
