E92 2008 LED Tail light replacement
11-29-2022, 03:55 PM | #1 |
Rep 22
Greeting, I have a problem with the rear left outside LED tail light on my 2008 E92.
After accessing the inside of the unit I discovered the LEDs themselves were working the circuit board is the problem and I have found out from this forum about the dry joint issues with the soldering. I tried to fix without success, when I affixed the unit back into the car I noticed the inner left LED lamp has now also stopped working. I have ordered a new outer LED (£160). When I put the new unit in will it work from the word go or do I have to clear any "faults" first? I have read on the forum that after a certain number of attempts the power is switched off to any faulty LED unit. I suspect this is why the inner LED is not functioning. I have an iCarsoft i910 machine but I cannot find any code clearance options for rear light faults. Any advice welcome. |
