2005 E90 frm to frm3 retrofit issues
11-27-2022, 09:55 AM | #1 |
Rep 5
Hello, recently I've changed my frm module to frm3 (LED Basis) as my car has lci halogen headlights and lci tail lights. I've changed the vin, coded the frm3 module to my car and coded out the warm and cold bulb checks for brake lights, brake force display and rear turn signals. The issue is that the outer tail light LED strips are not working on both sides (the ones on trunk work flawlessly), also the brake light is not dimmed and is very bright on outer tail lights. Side markers turn signals are not working as well. When the light switch is switched to off (0), pressing the brakes lights the brake lights as supposed to. Reading errots threw 2 FRM errors A8BA and A8B9, on ccc they show up as "rear light right failed" and "rear light left failed". Are these issues fixable with coding, before switching to frm3 all lights and led strips used to work perfectly.
11-28-2022, 05:18 PM | #3 |
21
Rep 73
https://www.e90post.com/forums/showthread.php?t=515630 scroll down a bit
