11-21-2022, 10:14 AM | #1 |
87
Rep 100
Only the left exhaust pipe seems to be working?
Hi all,
The 40i has two exhaust pipes as you may know, but of late I've seen exhaust fumes coming out of left pipe only. Doesn't matter if I've just started the car or I've been driving it for a few hours, I'm seeing vapour and condensation etc. coming out of the left pipe. Did not notice this behaviour in the summer, but it's extremely evident in colder temperatures now. After a relatively long drive of around 60 kms, I touched the tip of the right exhaust and it was absolutely cold. The temperature gauge was right where it is supposed to be when the engine is sufficiently warmed up. Is this expected behaviour? Do both exhaust pipes become operational when the engine gets really hot? Or is something wrong with the exhaust on my X5? I can post pictures if needed. There are no warning messages, no errors etc., anywhere that I can see. Nothing wrong with the way the car drives either. Everything is hunky dory so I'm a bit befuddled. Any pointers? Thanks & Cheers!
2021 BMW G05 X5 xDrive40i - Tanzanite Blue/Coffee Merino - 11/2023.50
2018 Audi Q5 45 TFSI - Ibis White 2018 Tesla Model S P100D - Midnight Silver |
11-21-2022, 12:53 PM | #3 |
87
Rep 100
Thanks! Does that mean the right exhaust never really works unless I rev the engine beyond 3000 rpm? It doesn't have anything to do with the temperature of the engine? And what about sports mode? If I switch the drive mode to sports(plus/individual) doesn't the flap open in that case?
11-21-2022, 01:32 PM | #4 |
2060
Rep 3,708
I don’t think it has anything to do with engine temp. It has to do with the exhaust gas velocity. At low rpm, flow volume is low, so one side is close to keep the rate of the flow “speed” high, lower pressure, actual help exhaust better. Engine gets better low end torque. Not sure if ever notice when people mod exhaust with mindless large pipe, they actually go slower. This is the reason. I think this mechanism is called exhaust scavenging, but I could be wrong with naming convention.
Having this said, I notice on my older bmws actually has this flap open in idle, so it give a louder sound. It closes when the car get moving until 3000ish rpm, the open again.
2022 G05 B58/PHEV
+ a few very old BMWs |
11-21-2022, 03:45 PM | #5 |
3214
Rep 6,885
Exhaust gas velocity is integral to spinning the turbo, so closing one off at lower RPM means boost sooner. AT higher RPM, too much back pressure will then also affect the velocity, cutting turbo boost, so to even things out across a wider RPM range, they added the flap.
sbc-yyc86.50 MJBradley1967196.50 |
11-21-2022, 04:47 PM | #6 | |
2060
Rep 3,708
Just want to shre, the 1 pipe closing scheme was in very early non turbo as well, like S62 V8, M54 Inline6.
2022 G05 B58/PHEV
sbc-yyc86.50 |
11-22-2022, 12:47 AM | #7 |
87
Rep 100
Wow. That's an amazing piece of information. Thanks all for sharing. I rest easy now, knowing it's all working as designed.
11-22-2022, 02:54 PM | #8 |
4504
Rep 7,548
here's some info about the exhaust flap
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
sbc-yyc86.50 |
11-22-2022, 06:03 PM | #9 |
20
Rep 84
So it looks like the use of this flap in the left ‘zorst is common across the different models.
The X3 guys and gals talk about removing the fuse to the flap actuator in order for the flap to remain open all the time, thereby having both exhausts functional at all times. Mostly to increase noise, particularly on startup. |
