11-20-2022, 05:12 PM | #1 |
57
Rep 138
How to clean evaporator in X5
6 months after service center replaced and cleaned the AC, the vinegar smell came back. Not sure why I keep having this issue, the first incident occurred a year after purchase (brand new 2021) and I had to take it in and paid $500 for cabin air filter replacement and evaporator cleaning.
Now it is happening again and I don't want to spend another $500 or planning to DIY. I did something similar on a Tesla and it was easy enough, basically just spray Kool-It foam into the slot where air filters are. I'm not sure if it's similar for BMW, especially in G05. No luck so far with google search. If anyone has info on this, please let me know. TIA |
12-05-2022, 12:15 AM | #2 |
1002
Rep 832
https://www.bmwx5info.com/cleaning_evaporator-2377.html
This may help |
nZtiZia4725.00 |
12-05-2022, 09:30 AM | #3 |
373
Rep 1,021
Do you run you AC -alot-
If you are running the AC alot and if the weather allows to just turn off the ac but leave fan on....the last 2 miles/few minutes en route to home to allow the system to dry out some and not have residual condensate. The vindegar smell is mildew/mold.... |
12-05-2022, 04:23 PM | #4 |
4725
Rep 8,803
Drives: eVeRyOnE mAD!
i have this issue, too. after 2 years of operation, it's been more consistent with AC use (we've had a mild winter so AC was still in use up until about a week ago). i'll see if they can add the cleaning to my yearly maintenance i already have scheduled next week.
12-05-2022, 04:51 PM | #5 |
373
Rep 1,021
casper/nti. Just buy a can of this and give it a go
https://www.amazon.com/nextzett-9611...NsaWNrPXRydWU= It's a well respected brand. I use their stuff ...some are decades old favorites. |
12-05-2022, 05:48 PM | #6 | |
32
Rep 84
08-23-2023, 03:36 PM | #7 | |
Rep 94
Were you successfully able to clear this up? |
08-23-2023, 03:47 PM | #8 |
229
Rep 509
On my Tesla, I was able to manage this smell by cranking temp and blower speed to the absolute max and letting it run for 20-30 minutes. Baking out the smell/bacteria seemed to work as well if not better than using the system cleaner sprays.
08-24-2023, 03:00 PM | #9 |
373
Rep 1,021
Cranking up the heat *post* issue doesn't really bake it out....
Black mould/mildew, whatever you wanna call is grows/builds up in wet dark conditions....which happens if you just turn off the AC and then park the car.... It needs to dry out before then..to prevent the growth in the 1st place |
Today, 07:11 AM | #10 |
186
Rep 1,485
Has anyone done this recently? I popped the side carpet panel off and the little plastic panel under the steering wheel off to have a look. I noticed there is a yellow removable cap on the driver side of the evaporator. I am wondering if that is where to insert the klima cleaner foam to clean the evaporator.
Today, 07:56 AM | #11 |
1281
Rep 1,063
There is so much crazy going on here that it's tough for me to wrap my head around.
First off, cabin air filter replacement is a diy job. It's a 10-20$ part on Amazon. Secondly, you don't clean inside the evaporator, it's full of refridgerant and is a sealed system. You MIGHT one day need to clean the evaporator coils, but no G05 is old enough for that to be reasonable. The evaporator will sweat onto a pan that will have a drain tube coming out of it. If you run your ac you should see a little.puddle under your car, maybe less in less humid areas, but here in FL it's a sizable puddle in the couple minutes it takes to get out the door after remote starting. If you don't have a puddle, might have a blocked tube that needs cleaned, bugs and stuff tend to like to crawl up in them. |
Today, 05:28 PM | #12 | |
Rep 94
