11-16-2022, 11:50 AM | #1 |
271
Rep 492
M550i low coolant
On my 2018 M550i I got a low coolant light. Car only has 26k miles. Dealer saying car needs 6 coolant lines cause some are leaking. They also stated upper and lower oil pan gaskets are sweating and needs to be changed. Video sent to me shows this also. They are saying it is about $13k in repairs as it is very labor extensive. Lucky I have extended warranty with Route 66 so they will send someone to the dealership to inspect. This to me is insane that a car with low miles needs that much repair. Costly as hell.
2018 BMW M550i | BM3 stg 1 | Resonator Delete (X-pipe) | Dark Graphite Metallic
11-16-2022, 11:58 AM | #2 | |
1725
Rep 1,656
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
11-16-2022, 02:17 PM | #3 |
47
Rep 78
I have a 2022 M550i with less than 7k miles and I am getting periodic "low coolant" warnings.
Just took the car in for service - no issues. Still getting the warnings. Anyone know if there are coolant *sensor* issues on the G31 N63? |
11-16-2022, 03:11 PM | #4 | |
1725
Rep 1,656
Mine is a 2020 (same engine as yours) and I've been in twice now. All they do is top it off and pressure test the system and say its OK. Complete bullshit. If you're still getting messages, check your big coolant tank up by the driver side of engine. If they did not top off your coolant, i would call and let them have an earful for not doing that for you.
dhodory47.00 |
11-16-2022, 11:09 PM | #5 | |
617
Rep 929
dhodory47.00 |
11-16-2022, 11:31 PM | #6 |
162
Rep 761
I have a 2020 and was told it was normal...I'm sure even on the M5 forums "normal" is the SA response. This is the main coolant tank not the turbo intercooler tank.
11-17-2022, 09:26 AM | #7 |
447
Rep 750
Mine did it last week @ 12k miles (2021MY) Topped it off at the cost of £12 with Green coolant from the dealer. Low coolant message hasn't come back.
I wonder if the solution to the famous N63 burning off oil issues it to have it burn off coolant instead now haha |
11-17-2022, 09:57 AM | #8 | |
1725
Rep 1,656
The problem, as someone pointed out in M5, is there is no heat protection underneath the plastic tank. So even if its swapped by BMW under warranty, it will just eventually come back unless you put a thermal barrier in. One guy made his own. I cant believe BMW engineers missed such a simple thing to prevent this.
Gsavarese300.50 |
11-17-2022, 01:21 PM | #9 |
271
Rep 492
Just bitched to BMW NA and they asked for my VIN and phone number. I have extended warranty with route 66 and inspector went and agreed with dealer but regardless. This should not even be a warranty issue but a recall with so many having this issue. When the replacement part is metal over plastic it tells me they know its an issue and aren't taking responsibility for it.
HerkHealer1725.00 |
11-17-2022, 03:36 PM | #10 | |
1725
Rep 1,656
And I agree with you 100%, this should be a RECALL or at least a TSB. Having the SA's tell customers that coolant loss is "normal" is bullshit.
11-17-2022, 04:15 PM | #12 |
617
Rep 929
11-17-2022, 05:07 PM | #13 |
983
Rep 1,800
11-17-2022, 06:12 PM | #14 |
271
Rep 492
I have no issues with the tank and not sure if there is a metal one.
11-17-2022, 06:13 PM | #15 |
271
Rep 492
I can't find any info on this. My SA not acknowledging it either. Any links or information?
11-18-2022, 05:16 PM | #16 | |
1725
Rep 1,656
You should not pay anything IMO...........especially for a leaking oil cover gasket. Which is ridiculous to me on a car costing so much.
11-18-2022, 07:02 PM | #17 | |
271
Rep 492
11-18-2022, 07:09 PM | #18 |
1725
Rep 1,656
Nice. LMK how it worked out with the warranty. My factory expires in 0ct 2023 and I need a good company.
11-21-2022, 02:17 AM | #19 |
22
Rep 42
Mine had said the same with 10k miles. I bought bmw coolant off Amazon. Mixed it up and topped it off. 30k later still no issues. I just think they don't feed enough into the lined and when car drives certain amount sensors go off. I refuse to go to dealer for dumbshit
11-21-2022, 07:37 AM | #20 | |
271
Rep 492
11-23-2022, 05:59 AM | #21 |
271
Rep 492
Update: warranty company, route66 is covering the coolant leaks with turbo lines. About $8500. They will not cover the oil sweat from the oil pan because the inspector went there and saw no failure. No actual leak or anything that has failed. He said idrive isn't even saying you need oil. He said if it gets to that point and becomes a leak then they would also cover that. I'm more than happy with that arrangement. My cost will be diagnostic fee and coolant. So far this has been a good experience, little slow but it's ok. It's a 7 year 120k mile warranty through my credit union that I paid $2700 for and it's already paid off.
Joe-BMW337440.00 |
11-23-2022, 10:02 AM | #22 | |
1725
Rep 1,656
