10-26-2022, 09:20 AM | #1 |
40
Rep 26
Digital key locking/unlocking
When I use my phone as the digital key I can't seem to lock or unlock the car from the handle. I have to go into the my bmw app and do it. Someone tell me what I'm doing wrong haha
10-26-2022, 10:19 AM | #2 |
498
Rep 744
I just lay the phone on the drivers side handle closer to the back. Make sure your settings are set up correctly, I have mine set up so I don’t have to open the phone (or the App) for it to work.
10-26-2022, 10:26 AM | #3 |
4727
Rep 8,803
Drives: eVeRyOnE mAD!
can you take a photo of where/how you're placing the phone? you confirmed your settings are correct? do you have Express Mode on or off? if off (assuming iPhone), you have to unlock your phone first before placing it on the handle.
10-26-2022, 10:30 AM | #4 |
Unapologetic Tool Hoarder
736
Rep 966
https://g05.bimmerpost.com/forums/sh....php?t=1662903
I usually placed the phone centered on that mark with the midback or about volume button height lined up with the door handle. |
10-26-2022, 11:11 AM | #5 | ||
498
Rep 744
10-26-2022, 10:22 PM | #6 |
Rep 22
To learn the optimal tap location, I recommend sliding the key card and the phone with the digital key along the handle from the front to the back. When the door unlocks, you will know where the NFC reader is. (The reader is in the middle of the handle.) You can slide your iPhone up and down on the middle of the handle to see what position the iPhone unlocks/locks the door. After doing this exercise a few times it becomes second nature to tap the middle of the handle with the correct part of the phone. You will remember the ideal location of the phone and key card to unlock the door and you can unlock or lock the door with a quick tap.
If you slide the key card along the handle and it doesn't unlock the door, then the key card isn't working. I have found that I can re-enable the key card and digital key by deleting them from the vehicle and then adding them back. |
10-27-2022, 11:14 AM | #7 |
29
Rep 56
My phone has started being more and more finicky, like it can take me up to 10 seconds or more to get it to lock/unlock sometimes, repeatedly placing the phone on the handle. The keycard is waaaay worse--can take me 5 minutes after returning to car from a run to try to unlock the damn thing. Be cool if it worked better.
