10-26-2022, 04:05 AM | #1 |
21
Rep 72
Rear Wiper Blade
Hey everyone, hope this isn't against forum rules but I posted this in the general thread...https://g20.bimmerpost.com/forums/sh....php?t=1965010
Quoted: Hey, sorry I have done a site search but can't find anything relevant. The rear wiper blade. When trying to lift it up to wash the window, is very very stiff. So much so I assumed there must be a particular mode you have to put it into, similar to the front wipers. Googling it and apparently not, you just lift it up normally. So this weekend I successfully lift it a few inches. The resistance was strong so certainly didn't try to lift the thing right up, and just did enough to get under. Ever since then, now the bl**dy wiper blade isn't getting proper contact with the window. If you imagine a half moon, the first and last 1/5 of the turn is being missed. So am I an idiot? Have I broken something? Thanks |
10-26-2022, 07:27 AM | #2 | |
6663
Rep 15,858
10-26-2022, 08:03 AM | #3 |
714
Rep 1,244
OP - sounds like something is definitely wrong with yours. Pic shows the position mine lifts to and this is very easy to do.
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
10-10-2023, 03:03 AM | #5 |
Rep 5
Hello,
I have a G21 LCI and it seems to be that I could have the same issue. If I try to pull the rear wiper, it lifts only a few mm and I feel a very high resistance. I see a part of the spring that goes in contact on the flat surface of the wiper and I am not sure if it is meant to be that way. What did the dealer say? |
10-10-2023, 07:46 AM | #7 | |
133
Rep 2,047
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport |
10-11-2023, 08:59 AM | #8 |
Rep 5
I think I figured it out.
In my wiper, there was a sort of pin which was preventing the arm to tilt. I needed to remove the cover to see that pin. Once the cover is removed, I pulled the arm sideways, like to extend the radius of the wiper. Doing so there will be enough room to remove the pin. Once removed the arm can be lifted up to about 45 degrees. If you pull hard enough, you'll be able to lift the arm and causing it to slide under the pin and pushing it out. I don't know why there is this additional pin, if to prevent wiper movement during the shipment of the car or during the wash. I put it back, i'll remove it only when I'll need. |
12-05-2023, 10:42 AM | #9 |
28
Rep 71
Thanks for sharing!
Picked up an LCI Touring a couple of weeks ago and have been having the same issue. Now I can only hope I didn't already make the rear wiper less effective after my attempts lifting the arm before learning about this. I can't believe this isn't explained in the documentation for the car! Where it only tells you to lift the arm and not a single word about any pin. m111 Did you pay the dealership a visit and asking them about this and if yes, were they able to fix the wiper to have full contact with the window again? I can imagine how all LCI Touring owners must be scratching their heads with the same question. Again, really strange how this isn't clearly explained in the manual! Last edited by WebMaximus; 12-05-2023 at 11:31 AM.. |
01-28-2024, 08:59 AM | #10 |
1141
Rep 2,250
came here looking for the same answer !
I did notice the pin thing, but didn't want to mess with it. seems this is a new standard change on all the LCI ones. Makes it hard to wash! |
01-28-2024, 09:13 AM | #11 |
28
Rep 71
Forgot to ask about this last time I was at the dealership but will make sure to ask about it next time.
Would be really interesting to understand what was behind this design change. Making it so hard to perform such a simple thing. And again, not even explained in the documentation for the car. Not particularly impressive. |
04-23-2024, 05:06 AM | #12 |
Rep 2
So I think I may have lifted my wiper arm higher than it should have gone before reading this, it is now not pushed tight against the window like it should.
Anyone got a solution, do I need a new pin or should I go back to BMW cap in hand? |
04-23-2024, 05:21 AM | #13 |
28
Rep 71
Sorry to hear that. I was close doing the same thing but stopped trying in time when I felt the resistance.
If you end up going back to BMW, please let us know what they said. I have an appointment scheduled myself to replace my windscreen in a week. Will remember to ask about it this time and will let you know their response. |
05-02-2024, 02:20 AM | #16 |
28
Rep 71
Asked about this when I dropped my car off today to have the windshield replaced and the answer I got back from the technician was how the rear wiper blade arm isn't meant to be lifted more than a couple of degrees on the G21 model. According to him, the same thing is true of later 5 series models.
I asked him why they changed the design in this stupid way and why the information in the handbook still suggests you should be able to lift the arm 90 degrees but he was as clueless as we are. I told him someone in here (I think it was) managed to lift the arm all the way by first removing that plastic sprint of whatever it is blocking the arm but he said customers are not supposed to do that even if it's possible. So there we have it, stupid design for unknown reasons we have to live with it seems. |
05-02-2024, 03:03 AM | #17 |
58
Rep 141
05-02-2024, 03:29 AM | #18 |
28
Rep 71
Must be it 😂
I sent the technician a link to here for him to see the photos how it can be done by removing the plastic sprint. Really stupid design and what I find even worse is how it's not mentioned in the documentation for the car. |
05-02-2024, 03:32 AM | #19 |
586
Rep 1,234
I tried mine yesterday (21 reg G21, individual build). It does lift, but there's a little bit inside that gives resistance after a few degrees. But you can push past that and the arm lifts.
There was no plastic locking piece as others have mentioned, and the arm doesn't pull outwards. The whole thing seems quite different to what others have mentioned above. |
05-02-2024, 04:28 AM | #21 |
586
Rep 1,234
Yep. There's a little plastic lug that just flicks past a notch. Seems like a completely different (and better) mechanism.
