10-25-2022, 09:33 AM | #1 |
227
Rep 291
AC button help
Can someone explain how this button works? I am confused by what the button is doing! Sometimes I see AC in RED, then AC is White. Sometime SYNC showed up! Thanks…
10-25-2022, 09:50 AM | #2 |
200
Rep 353
If you push the top of the button you will bring up the HVAC menu. When you push the bottom of the button it toggles between AC on and AC off. If you turn the AC off and the climate system is synchronized left/right/rear, you will see Sync in the display.
altern814.50 |
10-25-2022, 10:07 AM | #3 |
4504
Rep 7,548
Red & white? What time of day are you seeing it change? White should be daylight...red should be dusk to dawn (evening).
This should also be explained in the various owner manuals. The one embedded in iDrive is easy to use and even has videos for multiple topics...and also has multiple search methods. There's also the online/app version...and the paperback version. There are videos on Youtube, as well:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
Guy Fleegman421.00 altern814.50 |
10-25-2022, 11:57 AM | #4 |
227
Rep 291
I see what you are saying. I tested it out. But, my confusion is AC and SYNC are not mutually exclusive. I can have both AC ON and SYNC at the same time, right? I see what the bottom button is doing now with the AC menu on the screen. It seems to me, AC and SYNC should be 2 separate buttons like most cars.
10-25-2022, 01:28 PM | #5 | |
13576
Rep 20,215
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
10-25-2022, 01:47 PM | #7 | |
4727
Rep 8,803
Drives: eVeRyOnE mAD!
jBwFellow37.00 |
10-25-2022, 02:34 PM | #8 |
227
Rep 291
I think I understand it now... The SYNC display confused me, when the AC is toggled to Off. I thought somehow the button can control 'SYNC' function which I use a lot because my kid like to mess with the rear HVAC control, I didn't want to turn off the rear HVAC control, sometimes others may use it.
Again, why is the display of SYNC and AC can't co-exist is beyond me. Thanks for all the help. |
10-25-2022, 04:42 PM | #9 | |
421
Rep 547
We've been trying to duplicate the "vent" setting my older cars had by turning AC off and adjusting the fan controls. It's not clear to me what impact changing the temperature would have -- we haven't tried fooling with that. Any thoughts? |
10-25-2022, 04:53 PM | #10 |
3214
Rep 6,883
Just be aware that opening windows in lieu of running the a/c uses more power. The cross-over seems to be about 25-mph...faster than that the induced drag uses more energy than the sleeker body and using a/c.
You should be able to turn the a/c off and retain the venting...haven't tried that though. |
10-25-2022, 05:02 PM | #11 |
4727
Rep 8,803
i believe that turning AC 'off' will disable anti-fogging sensors
10-25-2022, 05:21 PM | #12 | |
217
Rep 436
10-25-2022, 06:59 PM | #13 | |
13576
Rep 20,215
I would suggest keeping it on AC and make sure your air flow is set to outside. You could turn off the AC and do the same but it of course wouldn't get much cooler should the cabin start heating up.
10-26-2022, 08:57 AM | #14 | |
421
Rep 547
11-03-2023, 05:16 AM | #15 |
Rep 3
Hi All,
This is my first post on this forum. I recently welcomed home the all the X5. I was going through the manual and found two interesting buttons present that I have never seen on any X5 video i have watched. They are placed right next to the the front and rear defogger buttons (which are underneath the central AC vents). I have attached the image. Would appreciate the inputs of the members here. Thanks! |
11-03-2023, 07:20 AM | #16 | |
867
Rep 1,304
11-03-2023, 05:19 PM | #17 | |
4504
Rep 7,548
Many of us probably don't know what they are for...never seen them...so if you can reveal what the manual said they were for...you'd be educating many BMW owners that have never seen them before. BTW, the resolution of the pic is so fuzzy...I can't tell what the icon on the left is (even after enlarging the image). The icon on the right looks like a fan speed button...is that what it says it is in the manual?
11-05-2023, 11:35 PM | #18 | |
Rep 3
11-06-2023, 09:18 AM | #19 |
4504
Rep 7,548
Thanks for the update. Hopefully someone that has them will chime in with more info.
11-06-2023, 09:36 AM | #20 | |
182
Rep 335
11-06-2023, 01:27 PM | #21 | |
867
Rep 1,304
11-07-2023, 05:26 AM | #22 |
Rep 3
Oh! I gotta check it out then. Maybe there is a different location for it on my car. Could be on the screen. And these could be exclusive to the PHEV version
