10-14-2022, 07:48 AM | #1 |
Rep 81
BM3 435i e85 high rpm stutter?
Hello,
Want to get another set of opinions on a issue: I have a 2016 435i and have full bolt ons and just installed dorche hpfp stage 2 and precision race works stage 3 lpfp (safe for ekp). The sensor and fuel pumps work great, and the power added by running ethanol blends is insane. However for some reason, the car seems to be stuttering around high rpms (5k) right before a shift or at the end of the pull. It went away after a few days when I was on e62 blend, but now I'm on e75 after a fill up and it's doing it again. I've heard some people call this stuttering breaking up? I have a few logs I'm gonna send over as well, looks like throttle closure from overboost too. Could this just be like an adaptation period each time the e blend changes? Or do I need to change the spark plug gap or look at other things on the car? (they were changed not long ago.) or maybe the stock turbo is maxed out? PTF said it looks like the car leans out and the stft are bad at 1? They said unplug the MAF sensor or look into the injectors or o2 sensor being the culprit? The plugs were replaced not long ago and gapped to .022. This only seems to happen on high ethanol blends, but I see a lot of others having overboost problems with these new multimaps. I attached a few logs where the car breaks up in the high rpm's. Wanna make sure this isn't a problem when I put in my upgraded turbo 🥴 E62 blend https://www.bootmod3.net/log?id=6343...0b43afee4ba088 https://www.bootmod3.net/log?id=6343...0b43afee4ba089 https://www.bootmod3.net/log?id=6343...729bae68633691 E75 blend https://www.bootmod3.net/log?id=6345...90c6e0a56a1dd2 https://www.bootmod3.net/log?id=6345...729bae68634283 |
10-14-2022, 12:37 PM | #2 |
4374
Rep 7,624
You can try unplugging MAF and relogging. You dont have LTFTs in your logs so you can't see if there's a LTFT issue.
It is odd that your STFT goes to 1 a few times - for some reason the car is going back into open loop, which could in theory be from a bad O2. Aside from that there's nothing that really shows why it could be breaking up after 5k. Fuel pressure is fine so its possible its the plugs, did you ever try stock plugs and stock gap at high E%? The throttle closure in the one 75% log is from overboost |
10-14-2022, 12:41 PM | #3 | |
Rep 81
Edit: also don't see LTFT as a log option in bm3 Also saw that some run .020 when using e85? |
10-14-2022, 01:36 PM | #4 | |
4374
Rep 7,624
LTFT should be there, ive seen it in other people's logs. You want the largest gap possible. Yes we all know thats the BM3 recommendation and most people blindly follow it even when its not needed and potentially even detrimental. It may be that in your case with high boost and ethanol you need an even smaller gap but generally speaking i would try stock plugs stock gap and only go down from there if necessary. |
10-14-2022, 01:59 PM | #5 | ||
Rep 81
Thanks for helping me with this 3 https://www.bootmod3.net/log?id=6349...0b43a0ea848ff0 4 https://www.bootmod3.net/log?id=6349...729b87653e1e4c |
10-14-2022, 02:38 PM | #6 |
4374
Rep 7,624
Could just be misfires from plugs or coils. As BM3 said, it does look like it gets some lean spikes in AFR up top and STFTs start adding more fuel all the sudden. If you have a misfire, the unburnt O2 in the exhaust shows increases the AFR. Not sure what else you can try in terms of datalogging before just trying different plugs/gap
10-14-2022, 02:47 PM | #7 | |
Rep 81
Thanks ! |
10-14-2022, 02:48 PM | #8 |
4374
Rep 7,624
You could start by going down to 0.020 with your current ones. IF going smaller doesnt work, i would go the other direction and replace all plugs with new bosch at stock gap
10-14-2022, 03:01 PM | #9 | |
Rep 81
10-15-2022, 03:53 AM | #10 | ||
38
Rep 107
Seems everyone's car reacts a little different but, yeah I would just follow Jeremy's advice. If gapping down doesn't work go the other way. Hopefully it'll solve your issue like it did mine
2016 M235i RWD 6MT, Full E85 Custom Tune via BM3, Stock Turbo, DS2 hpfp, stock lpfp, VRSF bolt ons, CTS Turbo Inlet
10-15-2022, 04:44 AM | #11 |
364
Rep 779
Just an FYI, We are all fairly positive the PR stage 3 pump IS NOT safe for the stock EKP. The stage 2.5 pulls enough amperage to melt the ground pin on the EKP.
10-15-2022, 07:22 PM | #12 | |
Rep 81
Gear 3 https://www.bootmod3.net/log?id=634b...0b439dc6593fcf Edit like 20 mins later: I just reflashed the car and went down to e59 blend and it's not breaking up anymore. Maybe these multimaps stink idek |
10-15-2022, 10:33 PM | #13 | |
Rep 81
We will see what happens 🥴 |
LA1Z24363.50 |
10-17-2022, 11:13 AM | #14 | |
4374
Rep 7,624
