10-14-2022, 01:45 AM | #1 |
Rep 108
N57 light hesitation
On very partial throttle i have hesitations. As soon as i give it more gas the hesitation clears and under full throttle it works perfectly. I am going to first change my fuel filter in case it is clogging.
I have a DPF delete, EGR delete, water injection, large intercooler and a custom remap. FYI Any ideas would be greatly appreciated. Thank you |
10-14-2022, 02:44 AM | #2 |
6443
Rep 8,510
Depends what you mean by hesitation, and at what rpm. Misfire ? Cough ? Delay and then smooth power ?
It could simply be turbo lag. Unlikely to be a badly blocked fuel filter - lack of throughput would get worse as the fuelling increased with rpm and load. Is the EGR fully coded-out in your remap ?
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
10-14-2022, 03:40 AM | #3 |
Rep 108
Yes EGR has been fully coded out and the vehicle has been running fine without it for around 2 years.
It's like a misfire and bucks very slightly, this is with very minimal throttle so it's not very noticeable. As soon as i put on more throttle the engine runs fine. I will check for any DTC's later. |
10-14-2022, 08:34 AM | #4 |
6443
Rep 8,510
Are you sure it's not transmission lash ? If you lift off the throttle, and then re-apply, does it feel the same as your perceived engine hesitation ?
10-17-2022, 04:39 AM | #6 |
Rep 108
Cars milage is 160k miles. There are no DTC's. It happened more noticeably yesterday i was at about 1/3 throttle and when accelerating it's like the engine "paused" for a second and then began accelerating again.
I have not done a gearbox service in the time i have owned the vehicle. |
10-17-2022, 06:22 AM | #7 |
6443
Rep 8,510
Have you checked/cleaned the Mass Airflow Sensor and the Mass Air Pressure sensors ?
10-20-2022, 09:48 AM | #9 |
6443
Rep 8,510
I think it's unlikely to be the root of the problem but it's always eliminating the simple things first.
10-28-2022, 05:33 AM | #11 | |
559
Rep 1,502
Drives: F36 435xd
Or guibo…or engine mounts. I have a little bit of the same and will get above checked next time it's in the shop
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
