F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [NBT EVO/NBT2]can't read fcs code from neither esys nor SW ID reader
ARMA SPEED
      10-06-2022, 09:03 AM   #1
bimmerhw
bimmerhw's Avatar
14
Drives: 2016 F30 340i
  [0.00]
Unhappy [NBT EVO/NBT2]can't read fcs code from neither esys nor SW ID reader
Hey guys,
I've struggled for a few days reading FSC from my f30. (2016 340i in australia).
tried SW ID reader(DE) also tried cic.
It got 0 byte.
Then I tried esys with psdzdata 4.32.12.
It got this error. also tried 0xDE, got same error.
can anyone please help me out?
there are two f020 versions, I tried both but got same results.
Thanks!
Last edited by bimmerhw; 10-08-2022 at 07:40 AM.. Reason: add nbt2 tag so more people got same problem can refer
      10-07-2022, 01:49 AM   #2
TheNine90
582
Drives: bmw
Do not use direct connection. Are trying to read or write FSC?
      10-07-2022, 03:03 AM   #3
bimmerhw
bimmerhw's Avatar
14
  [0.00]
Yeah, I was using the other ones. (in red boxes)
I am trying to read FSC.
      10-07-2022, 05:14 AM   #4
Wibbles
Coding ECU's remotely
Wibbles's Avatar
449
Drives: M3LR
For a start, there is no 1B cert in an NBT Headunit.
The problem is that you have NBT2 headunit - it says it there on Esys in the Base Variant field.
Given that case, and the year of your car, you can generate a map update FSC code if the headunit is ID4 (list menu only, not tiles).
Run the same job in esys but use: 0xF0 - zeroXFzero in the application number - if the unit is ID4 it will pull the FSC, send it to me and I will generate a code for you.
if you have ID5 then you have 2 options, buy a map update form BMW or install a set of fake FSC codes with lifetime map updates via USB.
EDIT - looked up your VIN, you deffo have ID4 NBT.
Appreciate 4
      10-07-2022, 07:20 PM   #5
bimmerhw
bimmerhw's Avatar
14
  [0.00]
Thank you! it finally works making a small move.
I can then see this when click edit button next to <save>.
not sure my decode steps are correct?
Loading the fsc file seems not working, it got an error:
then I copied the serial number(not sure it is a sn though..) at least no errors.
I got this file below when I copied the sn instead into the box but it looks garbled in UFT-8 BOM. I tried a few other encodes, no luck.
I think I can't upload files other than images, so copied the sn, is this helpful?
180E1982A323048368565693A74E6672CA39C8D3E1F6042189 48E2AEDE6DBF6195C32A9A3307CE65A896D277D1CA09E9BC11 E8C00503DD4ADDC60A18B4FCF3323DB2B631E5C4F8575263A9 DAB3876F088DCA42C83C77BC3094A2E7B544380D12F357D186 297F307A34908F0F7BD33F8D235FCC761617CF0B3B36DCB303 223644
      10-08-2022, 03:31 AM   #6
Wibbles
Wibbles's Avatar
449
Drives: M3LR
Attachment 3002301
Attachment 3002300
Attachment 3002305
Attachment 3002299
Attachment 3002298
Attachment 3002303
You won't be able to create your own FSC update code using that tool.
Save the F0 FSC from your car to your desktop - upload to Mega or Dropbox then PM me the link, I'll do the rest - no charge.
Appreciate 2
      10-08-2022, 04:57 AM   #7
bimmerhw
bimmerhw's Avatar
14
  [0.00]
Thank you so much!
I've upload to this link: https://mega.nz/file/E9FQHZyR#ynYd_4...TWOJMMSGtMjZB8
please try if it works.
btw, I still wonder why I can't use that <FSC generator> tool.
why I see other people do it so easy, lol (also saw another way is a usb tool which generate fsc file automatically once you start the car. it doesn't work for mine neither )
Is that my model special? or too old firmware
If I wanna diy that, how should I do it?
Much appreciated!
      10-08-2022, 05:22 AM   #8
Wibbles
Wibbles's Avatar
449
Drives: M3LR
Thank you so much!
Much appreciated!
Here is your code: CH7ZFMUEE4GZQAHXAD7A - this is a lifetime Map code.
The reason none of those tools work is because they are not for your headunit, they are either for CIC or earlier versions of NBT, not NBT2 which is what you have.
You can only DIY if you have some very expensive software, which I have. There are no tools you can download for free from the internet that will generate the right code for your headunit.
      10-08-2022, 06:13 AM   #9
bimmerhw
bimmerhw's Avatar
14
  [0.00]
Thanks a lot!!
I am actually also working on retrofit my SLI(8TH=SPEED LIMIT INFO), the map is for SLI too.(offline speed limit info when KAFAS not capturing, I can see I have the hardware camera based on some youtube tutorials, they says I only need activate it in ecu.)
In that case, do I need a combined fsc to make them both work?
[Updated]
Thanks man! Thanks to your FSC code, I've successfully updated my maps to latest version.
Wibbles449.00
      10-08-2022, 08:52 AM   #10
Wibbles
Wibbles's Avatar
449
Drives: M3LR
You need a 7E FSC code to activate SLI - I can supply for you or you can buy from a main dealer and activate yourself or I can do it remotely.
It's a 10 minute job - are you sure you have the Connected Drive camera in the windscreen?
      10-08-2022, 09:03 AM   #11
bimmerhw
bimmerhw's Avatar
14
  [0.00]
Yes I think so:
I've just managed coding to make it presents in instrument cluster and HUD.
It's too late so I didn't start the engine. Not sure whether it works, but I guess not.
since it's saying certa are not accepted.
I googled and saw that dealer won't sell it as a standalone one.
May I ask how much it would cost if I buy one from you?
Thanks a lot!!
      10-08-2022, 09:52 AM   #12
Wibbles
Wibbles's Avatar
449
Drives: M3LR
Yes I think so:
Attachment 3002638
Attachment 3002637
Attachment 3002636
Thanks a lot!!
Yep, it's possible on your car - PM me for a price.
      07-30-2023, 09:50 AM   #13
RavaN
No_Country
Drives: BMW F30M
entrynav
Hello Wibbles, i have hu_entrynav,
i want to update to this map
Road_Map_EUROPE_WEST_Route_2023-2
Road_Map_EUROPE_EAST_Route_2023-2
i got the FSC file, can you generate a code also for entrynav?
      07-30-2023, 12:31 PM   #14
Wibbles
Wibbles's Avatar
449
Drives: M3LR
yes I can
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube
      08-09-2023, 05:54 PM   #15
jihsan
Drives: bmw
yes I can
Can you do mine? PM me please.
      08-11-2023, 03:14 AM   #16
Wibbles
Wibbles's Avatar
449
Drives: M3LR
I replied to your PM
kdwor0.00
      08-13-2023, 02:13 AM   #17
V.I.P.
Drives: M4
Hi Wibbles, dropped you a PM.
      08-13-2023, 02:16 AM   #18
Wibbles
Wibbles's Avatar
449
Drives: M3LR
I know, but busy with family and weekending
I'll get back to you today.
      08-13-2023, 03:03 AM   #19
V.I.P.
Drives: M4
Sure, no worries, enjoy the Sunday!
      09-09-2023, 06:16 PM   #20
skkeptik
Serbia
Drives: Bmw f10
g30 fsc code map
bro i have repair fsc pack, i just need code for my g30 navi update can you generate fsc code for me . if you can i try to send you pm
      09-21-2023, 08:40 AM   #21
TheNine90
582
Drives: bmw
I can generate FSC for map updates. PM me if you still need it.
      11-14-2023, 02:37 AM   #22
Xxblinddzxx
Drives: F30 340iX 2017
matter of fact... i do i screw up my damn gps
NA 340i f30 2017 NBT2 if needed =)
Tags
bimmercode, ecu, esys, esysx, fsc, fsc code
f30post
