10-05-2022, 07:22 PM | #1 |
Rep 9
Yet another PCV chirp thread, pls help
Hey Bimmerpost,
I have a 2012 F30 335i, I purchased it with a jb4 and an upgraded aluminum? chargepipe. However, I cannot find a name on the pipe anywhere hence the question mark. I have been having issues with my crank/pcv system for the past while. I did purchase a car-shield third party warranty contract around the time I got the car. I have taken the car to two different places so far. The first of which was a reputable indy near me who suggested a smoke test and for me to take the car to a tuner, or "speed-shop". After doing my research, I chose APM tuned over in Villa Park, IL with the preface of PCV issues. So far, we have removed the jb4 which I was told was causing the 28A0 code. I opted to switch over to a custom tune from them, and since then I have been code-free. I received the car back after the new tune, and I was still having PCV issues and rough idles at stoplights/most starts. I took the car back, and we replaced the valve-cover through my warranty. It was a difficult and time consuming process but we got it done nonetheless. The chirp and rough crank have returned, and the car seems to be running lean on most starts. I have not driven it other than to replicate the noise. The chirp/squeal seems to be much quieter, however still present. I am also a little concerned about the loud beep and "clock ticking" noise you can hear at the beginning of the second clip in this video. I have scoured every forum, thread (including the one with 39 pages and ending with both crank seal replacements), reddit post, service bulletin, and youtube video related to this problem and I am at my wallet and wits end with this issue. I would need my friend's tablet to provide logs. Symptoms: Chirp Rough crank/Engine shaking side to side for 3 seconds or so 28A0: Throttle valve opening angle absolute pressure intake pipe comparison pressure too high Jerky/sensitive throttle response Running lean on start ups The automatic downshifts/engine braking feels very sluggish but maybe that is just placebo. Parts removed/installed: Jb4 OEM coils and plugs (bosch) (delphi) Valvecover (Warranty purchased this and shipped it to APM, authenticity of it being OEM is unknown.) I believe the eccentric shaft sensor has a lifetime warranty. Please help!! Last edited by J4CK_335i; 10-05-2022 at 07:22 PM.. Reason: forgot to link video :( |
10-05-2022, 08:16 PM | #2 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
The noise and clunk you hear in the second clip is just your throttle body I believe. My gti made that noise during throttle calibration, and my 335 does as well.
10-05-2022, 08:30 PM | #3 |
Rep 9
