09-21-2022, 03:43 PM | #1 |
Rep 24
F30 320ed air mass problem or not?
Hello i use bimmertool expert and air mass is excepted araound 1600 mg/stk but my car have only 300-400? What is problem? U can check csv file with parametara. Thanks in advice.
https://drive.google.com/file/d/1tC0...w?usp=drivesdk |
09-21-2022, 04:12 PM | #2 |
1419
Rep 1,817
At idle you will not see 1600mg/str. Do you see an actual problem with your car or codes?
I see up to 900mg/str when you had a bit more fueling. It looks fine. 1600 is a mistake in that app.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 09-21-2022 at 04:23 PM.. |
05-02-2023, 02:58 AM | #5 |
Rep 3
I spoke with the app developer and that is the answer
"Hello You are right, however this is the value provided by engine ECU. It is not the app issue. Older cars show expected air mass correctly. Late E-Series and the whole F/G series show high constant number. Only during DPF regeneration the real expected value is shown. Regards Paweł" |
