08-04-2022, 01:07 PM | #1 |
Rep 5
F30 N55 Valvetronic Issue 134F02
Hi guys I'm having an issue with my N55. When I first got it it had misfires on 5 cylinders, and Valvetronic code for ADJUSTMENT FAULT TO FREQUENT. I noticed someone was previously working on it and replaced the spark plugs and coils and was moving the injectors around. I came to the conclusion that it's the Valvetronic and not a misfire causing the issues. I opened up the valve cover and removed the motor and felt that the shaft was too stiff so I changed the shaft and the Valvetronic motor. Installed it and checked everything and put it all back together. Ran Ista+ Start up Valvetronic and it passed all 500 something cycles. From there I drove it to the gas station, ran smooth no issues at all got it up to 80 mph with no issue and after I filled up gas and went to start the car I started getting a low misfire and drivetrain malfunction. I noticed that it was the same issue again ADJUSTMENT FAULT TO FREQUENT. So I drove it back in limp mode. I then took off the Intake Manifold to inspect the valves and they were so dirty. So then I did a walnut blast on the valves and tested the car and no luck. I found a function for walnut blasting and I couldn't do it because of the misfire so I went ahead and bought all new spark plugs and the misfire almost went away, it's so small that the DME won't turn off the injector ran the test and then ran START UP VALVETRONIC but the Valvetronic would not cycle at all. All of my connections are good, I hear the car cycle when I open the door. I even reflashed the DME twice and still no luck. I now just get code 134F02 STOP NOT LEARNED I'm not sure what to do from here, my guess is that the DME is faulty. Does anyone have any suggestions? Thanks for reading
08-04-2022, 03:35 PM | #2 | |
399
Rep 666
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
08-05-2022, 06:47 AM | #3 |
3611
Rep 10,373
Confirm that the connector for the valvetronic motor is dry (no oil).
Did you replace the seal? What else is ISTA telling you?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
08-26-2022, 01:32 PM | #4 |
Rep 5
Hey sorry for not replying, I stopped working on the car, I have already changed everything (Valvetronic Motor and shaft) I ended up doing a adaptation reset and now I only have a cylinder 2 misfire, i used to have a Cyl 3 and 4 misfire. It's got, new coils, injectors and spark plugs. I even changed them between cylinders and it's all the same. Compression test came out to 180 on all cylinders. I'm thinking the intake and exhaust valves need to be adapted but I'm not sure what functional test to use. The start up after walnut blasting seems to be sort of what I'm after but I can't use that test because my check engine light comes on quickly. Does anyone have any clues?
08-26-2022, 01:34 PM | #5 | ||
Rep 5
1 is Valvetronic stop position not learned 2nd one is Cyl 2 misfire |
08-26-2022, 02:50 PM | #6 |
3611
Rep 10,373
Just to confirm. When I say no oil I'm talking inside the connector.
09-26-2022, 08:18 PM | #8 |
3611
Rep 10,373
Did you replace the needle bearings when you also did the eccentric shaft? Was the oil squirter which feeds the valvetronic motor clear? How did the camshaft ledge look?
