07-29-2022, 03:00 PM | #1 |
71
Rep 104
Driver Restraint Malfunction
Hopped in the car yesterday and I get "Driver Restraint Malfunction" msg on the dash. I've tried shutting the car off completely. Pulling negative battery cable for 3 mins. Any other ideas what it could be that might be an easy fix to try? I have an appointment at BMW on Aug 4th to check it out, but A, I'd like to fix before hand if possible, and B, it's a 3 hour drive 1 way for me to go to the dealer, so any help or ideas is much appreciated. Hasn't been in any accident or fender bender. No bumps. Only mod was the carbon fiber steering trim and paddles but that was 3-4 weeks ago and I've driven it plenty since then. Of course I disconnected negative battery first. I can't think of what caused it other than something just plain failing.
Thanks again folks! |
07-29-2022, 06:18 PM | #2 |
Violet and Violence
147
Rep 115
Check this thread out.
https://g42.bimmerpost.com/forums/sh....php?t=1922767 Guy "found" the repair manual. It might have something in there? |
07-29-2022, 08:35 PM | #3 | |
71
Rep 104
Siiiiigh. Lol |
07-29-2022, 09:28 PM | #4 |
Violet and Violence
147
Rep 115
just browsing through reddit, not much of a solid answer. Could be wiring harness, could be the seat module. The most common answers seem to talk about either stuff somehow got wet or the wiring harness is malfunctioning/loose. You could check under the seat to see if you find any wires that appear loose or damaged.
07-29-2022, 10:37 PM | #5 |
364
Rep 425
This is what the warranty is for. Just take it to the dealer and make them figure it out.
07-30-2022, 10:39 AM | #6 |
71
Rep 104
If course I am going to do that, but as it's a 3 hour drive away, and they seem to always need the vehicles for multiple days to fix just about anything, I'd like to avoid if possible.
07-30-2022, 01:13 PM | #7 |
71
Rep 104
Now I'm getting "Parking Assistant Malfunction". Again, nothing obviously brought this on. 1700 miles on the car. Wondering what else will just stop working...
07-30-2022, 02:13 PM | #8 |
Violet and Violence
147
Rep 115
