New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      12-17-2008, 02:46 AM   #1
ashkphong
Drives: e90 330i
No comfort access?
So there is no comfort access on the new z4???
      12-17-2008, 05:08 AM   #2
Z4 Beemer
Z4 Beemer's Avatar
Scotland
83
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
I thought I read somewhere that in order to operate the roof from the fob, you need Comfort Access...?
Can anyone confirm if this is the case with the 3 series cabrio...
E89 Z4 sDrive 23i... for the more discerning driver
      12-17-2008, 06:09 AM   #3
GeriFix
GeriFix's Avatar
Australia
21
Drives: BMW M3 E92; MG TF 160; C2 VTS
2008 BMW M3 E92  [0.00]
<snip>
You are correct. It's in the press release:
"The retractable roof may be operated either by a switch in the center console or by remote control key fob when equipped with optional Comfort Access. Comfort Access also allows convenient loading and unloading of the luggage compartment with the roof open. To provide access to the luggage compartment in this case, the open hardtop is moved to an interim position facilitating the removal of large objects."
      12-17-2008, 02:22 PM   #4
E89.35i
Drives: B
well, i think i saw the START button
      12-17-2008, 03:22 PM   #5
ashkphong
Drives: e90 330i
Thanks!!!
      12-17-2008, 03:25 PM   #6
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
^ nice find.... thanks
CA is a must in that case!!
      12-18-2008, 06:15 AM   #7
mkoesel
Moderator
7509
Drives: No BMW for now
Start button is not the same as comfort access though.
Yes, the Z4 does have comfort access, but even cars without it will still have the push button start. Comfort access takes that a step further and does not require the key to be inserted into the slot in the dash prior to start. It also of course allows entry to the car without using the key fob buttons and a few other things as discussed in this thread.
      12-18-2008, 06:19 AM   #8
mkoesel
Moderator
7509
This is indeed the case for the 3 series and M3 cab, and is now also true for the new Z4 as well. However, there is also a relatively inexpensive ($300) add on called "Smart TOP" that will allow you to do the same thing. In fact, it not only adds the ability to open and close the top from the remote, but adds the ability to do so with a simple extended-click or double-click, instead of holding the button for the whole procedure. And this goes for both the fob and for the switch in the car on the console.
      12-25-2008, 09:22 PM   #9
kronzprinz
kronzprinz's Avatar
Drives: 2008 M3
why would you think that???
      12-26-2008, 02:41 PM   #10
ashkphong
Drives: e90 330i
http://www.bimmerpost.com/goodiesforyou/z4catalog.pdf
there's no mentioning of comfort access on the full option list (-:
      12-26-2008, 05:35 PM   #11
Wondermike
Wondermike's Avatar
Drives: 2007 SLK350 Auto
Hmm strange there is no mention of it other than the press release, maybe it won't be available from launch.
Mike
2007 SLK350 Auto
      12-27-2008, 07:59 AM   #12
maniac
Drives: 320d se '06
It is mentioned in the german pricelist
Search this Thread:
Advanced Search
zpost
