07-23-2022, 12:58 PM | #1 |
486
Rep 1,206
DAPP?
I need your help. I have been reading conflicting comments. Some went as far as saying that DAPP cannot be used when driving on surface streets. Some say it is not useful for that purpose. Some say that they use it all the time on surface streets. Most of my driving will be on surface streets (light traffic). I don't drive that much (2 to 3 times a week). Occasionally I drive on the freeway.
The configurator lists those functions. I need opinions as to which functions would be useful when driving on surface streets? I'm trying to figure out if it is worth it for me to get it. Active Driving Assistant Pro Features like: -Steering and Lane Keeping Assistant -Lane Change Assistant -Emergency Stop Assistant -Evasion Aid assist the driver during critical driving situations, such as a health emergency or the sudden presence of vehicles or pedestrians in front of the car. Extended Traffic Jam Assistant for limited access highways Traffic Jam Assistant provides partially automated steering input on certain roadways up to 40 MPH in suitable driving conditions. |
07-23-2022, 02:43 PM | #2 |
2058
Rep 3,708
DAPP can be enables anywhere anytime. Useful or not, it is really your call. Personally I found it as safety buffer for short drive, in town, surface road. . I am feeling tired or could potentially be distracted, I turn it on. For longer drives, I use it very often even with similar feature in other brand. Just keep in mind, it is safety or fratique mitigation, you should not 100% rely on it drive you home.
07-23-2022, 02:48 PM | #3 | |
486
Rep 1,206
07-23-2022, 04:00 PM | #4 |
73
Rep 171
It works on any road with lane markings. I use it mostly on the highways, but sometimes use it on streets too if I'm stuck in stop and go traffic.
07-23-2022, 04:37 PM | #5 |
2767
Rep 4,397
I just leave it turned on and let it do its thing, it knows when to enable its features. You do get some options in iDrive when setting it up as to how aggressive or mild to instruct it to help out so you can play around with that to find the setting you like the best. I think its a feature worth having and can tell you one thing, if you don't have it, you'll always be asking that same question
Brigitte485.50 |
07-23-2022, 04:43 PM | #6 | |
486
Rep 1,206
07-23-2022, 06:13 PM | #7 | |
2767
Rep 4,397
This time around, since BMW zapped many of the features/options I wanted on late model year 2021 and all of 2022, I decided to look for an early model year 2021. Took me 1.5yrs but I found it and the only thing I wanted that it didn't have is the spare tire option, so am buying one aftermarket. This time it was worth the wait. |
07-23-2022, 06:44 PM | #8 | |
486
Rep 1,206
07-23-2022, 09:01 PM | #9 | |
1667
Rep 863
Drives: BMW Z4 M40i, BMW X5x40i
As others said, lane markings are everything. If there is a problem, DAPP beeps and flashes the icon telling you you have to steer. It normally resumes after just a few seconds. Some things I've learned to watch for: Intersections: Depending on the size and how they're striped DAPP will stop tracking. It will resume after you get through the intersection. Bad/low contrast striping: We have an elevated section of freeway near here that is white concrete with white stripes that have thin black lines to help the contrast. They're hard for me to see in some lighting. Depending on the sun, DAPP frequently loses it. Construction zones where lanes have shifted several times. Sometimes the old(removed stripes) are still visible and DAPP tries to follow the wrong lines. Expanding number of lanes/turn lanes: In that initial section where lines defining your lane starts to expand to two lanes and you haven't reached the stripes separating the lanes, DAPP will try to keep you in the 'center' of the widening lane. It just takes a bit of steering to hold your lane until it picks up the new stripes. But those are all minor annoyances. The lane keeping, distance keeping, and auto lane changes are worth it. And in heavy backed-up traffic, the Advanced Traffic Jam Assistant is wonderful. Just watch it do its thing. Gerry
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
Brigitte485.50 |
07-23-2022, 09:55 PM | #10 | |
486
Rep 1,206
07-23-2022, 10:16 PM | #11 | |
147
Rep 196
It is hands free driving on stop and go traffic under 40 mph on highways. Here in Houston coming back home it is indeed a great great help - 1.5 hr drive home for me
2022 X6 x40i MSport black sapphire / Cognac
Brigitte485.50 PittsDriver387.00 |
07-23-2022, 10:27 PM | #12 |
486
Rep 1,206
Thanks for answering my question. You said "on highways". Can it be used on surface streets?
07-23-2022, 10:32 PM | #14 |
486
Rep 1,206
07-23-2022, 10:43 PM | #15 |
58
Rep 89
Traffic Jam Assist works pretty well in traffic <40mph on highways only. It uses the camera in the dash to track your eyes so you will need to constantly look at the road. Not sure if others experienced this, but I wear glasses and about 1/10 times it deactivates on me as it can't track my eyes. I've even tried staring into the camera and the deactivation warning just keeps going off
Brigitte485.50 |
07-23-2022, 11:15 PM | #16 | |
486
Rep 1,206
BTW...I wear eyeglasses/prescription sunglasses...so I will have the same problem you're having. |
07-24-2022, 02:16 AM | #17 |
58
Rep 89
Interestingly enough it only happened when wearing prescription glasses. It never happened when I wore non prescription sunglasses.
As for why only highways, these systems are fairly new and very prone to errors. A divided highway has a lot less variables than say a school zone. It definitely helps take the stress away in traffic, but sometimes it feels like a being driven by a teenage driver. Though I must say the BMW system is quite good compared to other manufacturers. It was the first option I checked and well worth it in my book. |
volodp199.50 |
07-24-2022, 02:27 AM | #18 |
2058
Rep 3,708
I think the camera is looking at infrared spectrum, where they see through our sunglasses material. I used it today with Oakley black ice iridum lens, it sees my eyes just fine. But I do think the warming is too sensitive. If I look at instrument panel or even HUD, it will give me some warming
2022 G05 B58/PHEV
+ a few very old BMWs |
07-24-2022, 06:51 AM | #19 | |
13534
Rep 20,170
It is an optical camera that uses infra-red for lighting.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
07-24-2022, 08:00 AM | #20 |
420
Rep 546
It really is a cool feature. There's no way I know of to activate it manually. It just flashes on when it senses the conditions are right and you can then decide whether to activate it. I was in a 30-minute construction zone -- stop, go 10 feet, stop, repeat. It completely took over. I could have read a book.
Brigitte485.50 |
07-24-2022, 09:56 AM | #21 |
494
Rep 744
Actually it works on all roads, if there are no markings or poor ones lane keeping is disabled and it warns you to maintain steering control.
07-24-2022, 10:25 AM | #22 |
44
Rep 181
