Toyo Proxies R888 opinions?
12-16-2008, 06:39 AM | #1 |
2753
Rep 4,445
Anyone have experience with this tire at the track? I noticed a lot of cars running this tire at track days. It seems like it is a love/hate relationship. I would appreciate anyone's input.
12-16-2008, 10:13 AM | #2 |
434
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
I have done 4 track days on them so far...they seem decent...I think my worn pilot sport cups were slightly better..but this is by my butt dyno. I was doing about 1:47 laps at laguna with my pilot sport cups and my SSTT...(according to Harold at HP Autowerks) but I only got 1:49.X with my R888s and NO CHIP TUNING. I think I lost about 2 seconds with the tune..so I am thinking they are about the same gripwise..maybe slightly less than the pilot sport cups. But it is too friggin close to call. They are wearing nicely starting from full tread...an issue that I would have had to contend with if I had the RA1s.
Car is now gone .... :-( |
12-16-2008, 11:44 AM | #3 | |
2753
Rep 4,445
What size are you running? Do they heat up quickly?
12-16-2008, 11:52 AM | #4 |
434
Rep 4,380
I am on 235/40/18s on all four corners. I need to get wider tires in there..I need to roll my fenders...raise the car a bit..and get more negative camber. They do heat up quickly..or they did for me. I started with 34 cold..and when I got off the track..they were at 44-45 hot..I moved them down to 39-40 hot after each session.
12-16-2008, 11:56 AM | #5 | |
2753
Rep 4,445
So still no tune for you? Do you have an ETA?
12-16-2008, 04:16 PM | #6 |
118
Rep 3,432
255/35 is the correct size...255/40 will rub for sure
12-16-2008, 05:40 PM | #7 |
2753
Rep 4,445
You are right for 18 inch (I forgot S4 was running 18s), I think 17 inch rims wrapped in 255/40/17 will be ok.
12-16-2008, 07:31 PM | #8 |
Rep 86
Bubbles, I heard you have a hard time keeping your car on the track with street tires, you think r-comp are going to help? Just kidding but I am also interested in other peoples expriences with r-comp. Anyone using the Nitto NT01's?
12-16-2008, 10:51 PM | #9 |
434
Rep 4,380
I gotta go back to the dealership soon..for one more attempt at the misfire/rough idle issue...if they fix it ..I am going to the new Dinan office near me..already spoke to them about it. I hope to have this resolved by end of year. Crossing fingers.
12-17-2008, 06:20 AM | #10 | |
2753
Rep 4,445
12-17-2008, 06:20 AM | #11 | |
2753
Rep 4,445
Good luck!
12-17-2008, 09:11 AM | #12 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
That is good to know on the R888's. The Pilot Sport Cups are just a little better than street tires, takes a while to come up to temperature, very short window with max grip, then grip falls off sharply. May try to the NT01's next! |
12-17-2008, 11:18 AM | #13 | |
52
Rep 1,714
I've gone through a few sets of them and average 8-9 days on a set. No shaving, no heat cyclin', nuthin'. A lap generally gets them ready to rumble. |
12-18-2008, 12:59 AM | #14 |
Rep 103
Nitos work well, as mentioned no heat cycle needed, no shaving, etc. They can be shaved if you want, but I don't think there's much benefit. They wear very evenly and are very fast.
I would run the Nito over the Toyo, they are a bit cheeper and for some reason are actually faster from what I've heard.
Why does every Forum use a different signature format???????????
12-18-2008, 06:13 AM | #15 | ||
2753
Rep 4,445
No heat cycle required, just mount and run? I may have to lean towards the Nittos.
12-18-2008, 12:34 PM | #16 |
72
Rep 396
I have had 2 days and 1000 miles on NT01. It works great so far. On the street, the noise level is not as good as PS2 but bearable to the point that I decide to run NT01 regularly. It looks like I might be able to go 7-8 track days with this tire and couple grand on the street.
Since I only put less than 100miles/week on my car, I might as well keep them on there. Yesterday I decided to go to the Ralphs in a slight rain with NT01..to my surprise, it wasn't all that bad. Even though I had to take off in 2nd at stop sign but the slide was worth the fun. Be careful in the rain.. |
12-18-2008, 11:31 PM | #17 |
52
Rep 1,714
Holy crap, you run them on the street?!?! They hum like a mofo for me, even on track.
I have definitely noticed that they lose some grip after a certain number of heat cycles. I wouldn't run them on the street, but I luuuuuurve them for track use. |
12-19-2008, 09:05 AM | #18 |
434
Rep 4,380
luuuuuurve?
12-19-2008, 01:32 PM | #20 |
434
Rep 4,380
How do you know its the same compound? My contact at Toyo left..so I have no one to ask there anymore. Ugh.
12-19-2008, 01:55 PM | #21 |
3847
Rep 54,376
Drives: F80 M3
