How would you go ethanol in 2022?
07-16-2022, 10:02 AM | #1 |
190
Rep 2,232
With the release of mhd+ for n54, what is the best way to run e40+ with the new options. Right now the car is stock fueling wise but I'd like to build an ethanol capable platform without using outdated gear. Stock turbos for now but I want to get fueling right and eventually likely to go big single or pure stage 2. Still on the fence.
07-19-2022, 06:47 AM | #3 | |
2002
Rep 3,731
Now if you want to run straight e85, then you will need to step up to a full port injection setup, and probably install a second LPFP. Honestly, going to port injection is a waste unless you have a big set of twins or a big single turbo. You are talking 600+hp.
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
darkrom189.50 |
