07-14-2022, 11:22 AM | #1 |
261
Rep 666
how do I know if this slider works?
see attached picture
I try sliding it to hot and cold, but i don't feel any difference, still feeling cold AC air. so how do i know if it works or not? Thanks. |
07-14-2022, 11:52 AM | #2 |
163
Rep 259
I think you answered your own question. Make sure the air is directed to the top vents and if it is, the dial should adjust the temperature warmer even if the AC is cranked.
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
07-14-2022, 01:43 PM | #4 |
288
Rep 539
I leave my AC on full auto mode and there is definitely a difference in the top vents when adjusting the dial. It should be fairly obvious.
Wonder if the trim has been taken off for whatever reason and the electrical connector for it hasn’t been plugged back in |
07-14-2022, 01:59 PM | #5 |
3117
Rep 4,363
the slider is mixing in warm air to the cold a/c air.
it is an additional(manual) way to change the selected temperature slightly, without changing what you have set electronically. not sure why bmw put it there, since you can set whatever temp you desire. maybe if you have the AC off and slide it to full warm for heat during winter . |
07-14-2022, 02:06 PM | #6 |
70
Rep 131
Probably because Germans are superstitious about cold air giving them illness.
07-14-2022, 03:05 PM | #7 |
1388
Rep 2,129
All it is is a small piece of metal behind the vents that heat up slightly. It's not an instant change, it needs to heat up, but as previously mentioned, it's not a huge difference. It just takes the chill off the A/C
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
alohasurftoad3116.50 |
07-14-2022, 04:00 PM | #8 | |
6659
Rep 15,858
Say you are driving in an ambient temperature of 10C and CC set to 20C. Turn to blue and it will definitely be cold. To red, and it will add warm to hot air. Mid position will be blended, to be similar to the rest of the cabin heating. Driving in high ambient temperatures, and CC set to cool, the face vents will cool as we have a low temperature target. How we use Auto temperatures, can also change the output range. Remember it can change as you drive, as it also senses demand towards target settings. Driver and passenger settings can also have subtle differences. In my experience the driver has priority for its function. All BMW models I've owned (or driven) face level air stratification works perfectly, same in each example. Great feature, tuneable to personal preference. |
JoHnMuir70.00 |
07-14-2022, 04:07 PM | #9 | |
6659
Rep 15,858
In my experience if set to cold, will not blow cold while cabin temperature is wide off the target temperature. As the cabin warns, closes towards the target settings, the face flow starts blowing cold. Clever stuff, as you don't need to keep playing with the thumbwheel control. |
07-14-2022, 04:10 PM | #10 |
6659
Rep 15,858
07-14-2022, 04:14 PM | #11 | |
1658
Rep 4,899
You really notice if you are driving and you get sun and then cloud cover. On "blue" you will get a lot more cold out of the vents since it's aggressively trying to maintain your set temperature. |
07-14-2022, 07:39 PM | #12 |
Great Teacher
1115
Rep 1,311
Drives: 06 e91 325ix
You’ll notice it in the winter!
And when it is 104-110 out you can tell it is not as cold.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
07-14-2022, 09:20 PM | #14 |
1658
Rep 4,899
You need to re-read my post #11. There is no "warm air mixed with cold", it's purely a HVAC "aggressiveness adjustment".
07-14-2022, 09:44 PM | #15 | |
3117
Rep 4,363
for years, i felt my AC "coldness" was substandard. i only recently noticed the dial itself and it wasn't to the full blue side. that's what i get for not RTFM |
07-15-2022, 03:21 AM | #16 | |
6659
Rep 15,858
What temperatures are you working with, ambient and HVAC settings? |
07-15-2022, 03:32 AM | #17 | ||
6659
Rep 15,858
Typical technical description... Quote:
tturedraider5069.00 |
07-15-2022, 05:11 AM | #18 |
261
Rep 666
i tried again today, adjust all the way to auto and 60 F. then set the wheel to HOT.
i feel HOT and COLD setting the same, nothing changed... and yes, the plug is connected at the back, because the emergency blinker and central lock works |
07-15-2022, 06:27 AM | #19 |
97
Rep 431
I find it's best use is during the winter, I get a cool flow from the top vents to aid drowsiness when the heat is on and up to temperature. I run auto all year.
HighlandPete6658.50 Lance_Goodthrust4.50 |
07-15-2022, 08:33 AM | #20 | |
6659
Rep 15,858
What happens when you select a temperature 65 - 70 F, then try the hot to cold range? |
07-15-2022, 08:35 AM | #21 |
6659
Rep 15,858
07-15-2022, 08:58 AM | #22 |
1658
Rep 4,899
Mine doesn't work like that description (at least from my experience). But heh, results may vary!
