06-27-2022, 08:53 AM | #1 |
Rep 13
2015 - Cold engine hesitation. Warm OK codes 118401 and 118001
So our 2015 is riding the struggle bus right now. My wife was complaining the car would hesitate after the cold morning start. I confirmed and note once you get it above idle it clears up and then seemingly just goes away. Fire up later in the day, no problem.
It did throw the lean codes 118401 and 118001 I did spray starter fluid around and didn't notice any real change in RPM. PCV system or intake tube? The charge pipe/FMIC is aftermarket. |
06-27-2022, 01:19 PM | #2 |
Rep 13
Other clues - The car was doing this a month ago. I changed plugs and coils since it's at ~60k. In doing so I found the ignition/injector harness had some insulation chewed around cylinder 3. BMW replaced the harness a few days ago. Perhaps the injector shorted and was damaged? I would think that would cause an issue all the time, not intermittent.
I just jacked the car up and took a look at the following: Down pipe - tight, no signs of exhaust leak hot side charge pipe - tight, no signs of damage cold side - tight no signs of issues air inlet tube - looks ok, but it sure is burried oil fill cap - some oil build up below it. maybe...but the large deviation code seems something bigger valve cover - no obvious signs of leaks |
06-27-2022, 09:08 PM | #4 |
Rep 13
another clue
Also pulled a code for intake air temperature shorted to +12V ISTA says step one to fix the MAF. My understanding intake air temp comes from the MAF So I data logged tonight and noted the following from BM3 1) IAT shows normal. I also heard IAT could come from various sensors. Not sure which one BM3 uses 2) When it is in "hesitation" mode AFR is stuck at ~19:1, no osolating, nothing. Cruising speed it seems ok but still shows lean. Give it a few minutes of driving and AFR starts responding normally and the car drives like nothing ever happened. |
06-28-2022, 11:51 AM | #5 | |
4376
Rep 7,624
If the AFR is not moving then you have an O2, wiring, or software issue. The software issue being the least likely. A "tired" O2 can give symptoms like that. |
07-11-2022, 09:12 AM | #6 |
Rep 13
To follow up
O2 reading 19:1 warming up. This is normal until the sensor warms up. I replaced the IAT sensor located within the MAF which it eventually threw a code for Problemo solved. |
07-11-2022, 12:26 PM | #7 |
4376
Rep 7,624
07-14-2022, 09:17 PM | #8 |
Rep 27
I have an 2013 bmw 335xi m performance with a cold air intake and just recently the car has started to lurch when under load around half thorttle and have a loud whistle sound it isn't having any codes pop up ethier it doesn't do it if it's not under load or anything and it's not a huge lurch but u can feel it's struggling and if I put it to the floor the car seems to feel gutless if anyone has any ideas on what this would be would be nice thank you
07-15-2022, 07:10 AM | #9 |
Check out my Youtube @n55david!
1299
Rep 3,539
Drives: 2017 m240i, 2015 X3 x35i
There is one in the maf. Thats where ambient comes from I believe.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
07-15-2022, 01:58 PM | #10 |
4376
Rep 7,624
07-15-2022, 02:04 PM | #11 |
1299
Rep 3,539
Ahh lol yeah, have to replace the whole thing.
08-29-2022, 02:19 PM | #12 | |
4376
Rep 7,624
