06-10-2022, 08:22 PM | #1 |
Rep 31
Red Hot Alternator
Hey folks, just a casual 340i GT guy here.
I recently got my car coded with BM3 Stg 1 multistage OTS. The car ran fine on map 3 (stg 1 93 oct) a couple of days, then ran fine again today. After about ten minutes or so, the car was making some high pitched noise as I was pulling up to a parking lot, no dash indications. I pulled over and popped the hood while the engine was running and found my alternator with a single spot that was amber (heard) hot. I shut the car down, gave it ten minutes before starting the car again and booting the OEM map and heading back home while babying the throttle. I get home to find that the alternator is not red hot this time. I'll have to see if the map is what did it, but figured I would ask the folks as well. Has anyone come across a problem similar to this? Any help would be greatly appreciated! |
06-12-2022, 02:39 PM | #2 |
Rep 3
This doesn't make much sense the tune wouldn't make the accessory belt move faster. Or do anything that could affect the way the alternator functions. Most likely your alternator is about to fail, completely unrelated to the tune. You might have damage to your battery because of this. Seems you caught it early though try just replacing the alternator
06-12-2022, 04:46 PM | #3 | |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
Wires1657.50 |
06-13-2022, 06:22 AM | #4 |
1471
Rep 975
Double check the serpentine belt to ensure it's properly on the pulley. From what I have read, a slipping belt can cause this.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
BuckSM0.00 |
06-13-2022, 07:16 AM | #5 |
Rep 31
I didn't think it made sense for the tune to have caused this but that was also the only thing that changed in just prior to this issue so I had to try 😭
I didn't have this issue again on the map so I may have to replace the alternator.. I did check the belt and they seemed to be seated normally. Thanks for the responses! (Maybe not so much the "you have an issue" response LOL 🤣 |
