06-10-2022, 06:21 PM | #1 |
20
Rep 175
335i, Clutch A appears to be failing
So I got the xHP flash tool and took a look at the transmission values below. It appears clutch A is going.
What are my options at this and how much is it gonna cost? It;s a 2014 with 92k miles. Thanks, Aaron *EDIT* I should mention also that I'm having hard downshifts when slowing down from 3-2... https://freeimage.host/i/hc5KCJ Last edited by ajrettke; 06-11-2022 at 12:10 PM.. |
06-10-2022, 07:20 PM | #2 |
4376
Rep 7,624
Can't comment on whether or not that actually means its failing, but the best and pretty much your only (AFAIK) option for rebuild is https://www.puredrivetrainsolutions....-transmissions
06-11-2022, 05:33 AM | #3 |
Check out my Youtube @n55david!
1299
Rep 3,539
Drives: 2017 m240i, 2015 X3 x35i
Nah, you're okay.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
06-11-2022, 09:29 AM | #4 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
In another thread, I found guidance saying it's fine as long as you're within +/- 350mbar. I'm with n55david unless you're actively having problems with shifts.
Edit: these are old, but the last time I checked my values at 60k miles I had -126 for A, -126 for B and +184 for C. You're fine. Last edited by Eschmacher; 06-11-2022 at 09:39 AM.. |
06-11-2022, 12:12 PM | #5 |
20
Rep 175
K, thanks, I'll keep an eye on it and see if it starts to get worse. I forgot to mention though that I was starting to get hard downshifts from 3-2. I did a transmission flush when it started about two months ago and the system remained the same. I'm wondering if I should try a stage1 from xHP? Would that make it worse if or perhaps fix it?
06-11-2022, 01:36 PM | #6 | |
4376
Rep 7,624
XHP wont fix a mechanical problem, but it can improve shifting. |
06-11-2022, 01:37 PM | #7 |
Car Hypochondriac
335
Rep 903
Stage 1 should be identical to the stock calibration minus the torque limits.
06-11-2022, 02:01 PM | #8 | |
41
Rep 187
Drives: BMW F36 435i FBO
Mine shifted horrible after service, on a hoist. But after i figured out the gearbox wasn't level I could get 0.7L more in after adjustment. Now it shifts like butter You have to check right under the fill plug with a spirit level to ensure it is level. Not on oil sump since it is tilted |
06-11-2022, 08:07 PM | #9 |
20
Rep 175
It was the pan was dropped and replaced, done by my local guy I goto for anything I can’t do it don’t have time to. I’ll try and let the trans warm up and and top it off
06-12-2022, 01:14 AM | #10 |
41
Rep 187
Follow this procedure and use only ZF Lifeguard 8 fluid
