ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      12-12-2008, 08:03 PM   #1
krnnerdboy
krnnerdboy's Avatar
190
Drives: v10 m6
fuel line/filter location?? z4m
Hey guys,
just started an install for a 75 shot wet nitrous kit and am having trouble finding the fuel filter...according to the e46 m3 forums it's under driver seat(under the chassis) but not on ours...
I'm taking pictures of the install to make it as easy as possible for other z4 members to embark on this install, but I'm stuck on this????!!! please help
thanks guys
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      12-12-2008, 08:40 PM   #2
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Look for it in realoem.com. It's a great source for looking up parts/part #'s.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      12-12-2008, 08:51 PM   #3
krnnerdboy
krnnerdboy's Avatar
190
Drives: v10 m6
hey thanks,
that was very insightful.. http://www.realoem.com/bmw/showparts...41&hg=16&fg=15
according to the site our filter is built into the tank with the pump unlike the e46 m3... http://www.realoem.com/bmw/showparts...84&hg=16&fg=15
looks like i'll be tapping in the engine bay near the fuel rail instead...the only part of the feed line with rubber
thanks again !!
      12-12-2008, 11:10 PM   #4
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Awesome cant wait to see what times you pull with the no2.
Im just taking an educated guess here, but i think our engines would be able to take probably up to 150 shot safely.
Did you get window switches and all the other safety gear?
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      12-13-2008, 02:40 PM   #5
krnnerdboy
krnnerdboy's Avatar
190
Drives: v10 m6
I have the window switch for safety and that's about it, but I'm running the zex wet kit which has the WOT switch that actually runs off the tps. Looking to just run a 75 shot to get rid of my neighbors pesky m6 and hopefully run a low 12 over 115 is my goal.
My research shows that our motors can actually run upto 250shot but with a state of the art direct port system...on a single fogger it seems 100 shot is safe b/c of our intake manifold design...and 150 shot on any old direct port system....IRON BLOCKS
just got finished with the fuel tap and am moving on to cutting some wood for my bottle rack and then just programming my WOT and I'm finished!! look for a write up soon
      12-13-2008, 04:32 PM   #6
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Originally Posted by krnnerdboy View Post
hey thanks,
thanks again !!
No problem, good luck with the install!
Best Website EVER!
      12-14-2008, 08:32 PM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
hey thanks,
thanks again !!
Wait what.. that doesn't indicate that at all... It indicates it's somewhere forward of the fuel tank.
I should have my car up tomorrow for track de prepping and a caliper rebuild I'll look, but I'm pretty sure it's the same place the e46 one is, the shield is there and everything.
      12-15-2008, 08:45 PM   #8
krnnerdboy
krnnerdboy's Avatar
190
Drives: v10 m6
did you find the filter? I was under there for a while and the only part of the line that was rubber was the line under the intake manifold. It looks to be an inline filter in the tank...
      12-18-2008, 09:53 PM   #9
thread killer
14
Drives: faster then your car
fuel pump AND filter are in the tank.
fuel pump sits inside, fuel filter IS the white cap that is on the bottom of the tank.
you'll have to tap into the fuel line at the rail to get a wet shot working on this car.
      12-19-2008, 09:48 AM   #10
krnnerdboy
krnnerdboy's Avatar
190
Drives: v10 m6
thanks for confirming that!! I already tapped the line under the rail
      05-26-2010, 03:55 PM   #11
Zedfor
Meinkugelschmerzen
Zedfor's Avatar
Drives: 2003 BMW Z4 3.0i, B757-200
So to revive a dead thread with a question; do you have to drain the tank and remove the fuel pump in order to replace the fuel filter? How often should the fuel filter be replaced? I'm not a big fan of BMW's nothing until 100,000 miles plan.
If you don't know where you are going, any road will take you there.
ZSCCA
ZSCCA on Facebook
zpost
