Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 318d exhaust leak in cabin. (turbo lag)
      06-07-2022, 07:02 AM   #1
Alex Roman
Drives: E90 318d LCI
hi, this is for the N47.
I noticed the car throws a lot of exhaust fumes into the cabin when the a/c or cabin air is turned on.
Excessive fumes are also noticeable when standing outside the car.
it is very noticeable and even makes me nauseous so needs to be addressed.
I suspect it to be a turbo leak of some kind. Maybe so sensor housing has melted? as I've seen similar things happen to others. I also notice a considerable boost lag, however idk if this is standard for the N47.
the cabin air filter is new but I doubt that can make much difference in regards to exhaust fumes.
Any help would be much appreciated.
edit: No check engine light
      06-18-2022, 08:52 AM   #2
Lozza47
Lozza47's Avatar
38
Drives: 2013 F30 335i / 2011 E92 M3
Check intake charge pipe, at the intercooler connection, sometimes these plastic pipes crack.
In terms of the smell, could be a range of things. I had this problem when my egr valve was stuck open and my intake manifold melted and had a leak.
2011 E92 M3 - Mineral White - Pure Edition I
      06-22-2022, 07:13 AM   #3
Andystobbs
191
Drives: E91 Lci, Vectra B V6
Flexi section at DPF outlet.
