Idle air control
06-04-2022, 02:19 PM | #1 |
17
Rep 141
Having a rough idle almost all the time cold and hot. Getting 2ADF Idle air control, engine speed. Cars been smoke tested twice. No leaks. Lpfp and hpfp are fine. New ish index 12 injectors. No misfires during WOT, so plugs and coils should be fine. Suggestions on where to look next?
Edit I forgot to add it's a 07 335i |
06-04-2022, 03:21 PM | #3 |
17
Rep 141
06-06-2022, 07:52 PM | #5 |
17
Rep 141
Throttle body is clean as can be and the adaptions have been reset. Still getting the same code. Idle is still the same. I don't know where to go from here. I have new o2 sensors as maintenance maybe those will help. Valves are not perfect but they aren't bad, I did walnut blast it about 2k miles ago. I can post a log of what is happening maybe someone can find something I missed.
06-06-2022, 08:16 PM | #6 | |
654
Rep 1,893
Did you reset all adaptations or just throttle valve adaptation? Last edited by dpaul; 06-06-2022 at 08:27 PM.. |
06-06-2022, 08:25 PM | #7 | ||
17
Rep 141
06-07-2022, 09:40 AM | #8 | ||
17
Rep 141
06-07-2022, 01:41 PM | #9 |
654
Rep 1,893
06-07-2022, 02:42 PM | #10 |
17
Rep 141
06-07-2022, 04:01 PM | #11 |
654
Rep 1,893
I have no experience with single turbo installations and I think it likely complicates the diagnosis. But it would not hurt to reset all adaptations. There's one in there about "idle control" or "air control" that might be relevant.
06-07-2022, 04:24 PM | #12 | |
17
Rep 141
06-10-2022, 08:08 PM | #13 |
17
Rep 141
Idle adaptions have been reset resulting in nothing different. Lambda looks a little weird compared to my other logs but maybe just because the idle is acting weird. Here is a log maybe one of you can pinpoint something wrong I can't. Just my luck low pressure sensor decided to stop working over night.
https://datazap.me/u/antistockbmw/id...&data=3-21 |
06-11-2022, 08:56 AM | #14 | |
654
Rep 1,893
I know you said it was smoke tested but as you know, the simplest explanation would be either an intake leak of some sort or a PCV leak. Did you test with smoke input to the crankcase (i.e. oil filler cap) as well as intake (vacuum port of some sort lwith thottle body blocked)? |
06-11-2022, 10:11 AM | #15 | ||
17
Rep 141
