DId I make a fatal mistake??
12-11-2008, 06:00 PM | #1 |
Rep 3
Hi, everyone
So last night, when I tried to start my car, i had to crank it a bit long to start the engine. After driving for a few miles, I parked my car then went to do some business that I had to take care of. When I came back and started the car, it had a very long crank then the "Power Reduction Sign" poped on my screen. Also, the rpm meter was going up and down, then the car went off. As scared as I was, I started the car again, but the same thing occured. So, I towed the car to the dealership thinking that it would be the fuel pump. The dealership called me today, telling me that they will look at it tomorrow morning. He also added that the car has no fuel (however, if I remember correctly, I am sure I saw the reading that said the car can go another 20 miles or so). Did I make a huge mistake by assuming it's a fuel pump problem without checking gas?? If it is, I would be so ashamed to go back to the dealership |
12-11-2008, 06:04 PM | #2 |
Rep 3
Just have your wife or girlfriend go pick it up. Or sneak in and cut your own fuel line...
'09 335i e90. Space gray with black leather. Premium and cw packages. (wifes new ride/my new toy)
'08 FJ 6MT OR, Lifted, Winched and pinstriped all over. (My Passion) |
12-11-2008, 06:05 PM | #3 |
26
Rep 444
I would still guess its the fuel pump. If the car said it could go another ~20 miles with the current fuel in the tank, then it wouldn't cause the excessively long cranks and the limp mode (aka power reduction).
12-11-2008, 06:07 PM | #4 |
Rep 3
12-11-2008, 06:10 PM | #5 | |
Smiling Politely
1381
Rep 29,118
low fuel wouldnt cause a limp
12-11-2008, 06:18 PM | #6 |
663
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
12-11-2008, 07:02 PM | #7 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
Probably wouldn't cause a limp, but the question I have, WHY let the tank get so dang low?!?! I know tons of people do it, but I don't know why. I try to never let it go below 1/4 tank on any of my vehicles. Of course, the wife likes to drive until the fumes are gone too, but that is another conversation.......
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
12-11-2008, 07:46 PM | #8 |
36
Rep 388
that same thing happened to me with my 2005 X3, it said it had fuel, but wouldnt start, had it towed, and they said it was out of fuel, they replaced the fuel level sensor and gave me a tank of gas!
12-12-2008, 01:30 AM | #10 |
143
Rep 6,333
lol how about taking a shit in the pants in middle school...
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
12-12-2008, 06:04 AM | #11 | |
Rep 207
2007 335i Coupe Jet Black / Black Leather / Aluminum / Steptronic w. Paddles / Premium / Sport / CA / Navigation / Satellite
12-12-2008, 06:36 AM | #12 | |
1671
Rep 6,589
12-12-2008, 11:43 AM | #13 | |
137
Rep 2,372
Below 1/4 tank you increase the risks of: Fuel starvation from lateral g-loading due to low level of fuel in tank. Fuel pump is located in the tank, and is "cooled" by the fuel. At lower levels, that leaves the possibility of insuffient pump cooling, possibly causing earlier failure Running out of gas! How many times have you wondered if you'll make it to the station because you let the tank get so low? But hey, it's your car, do what you want. Does it help to fill up at 1/4 tank? Maybe. Does it hurt? Most certainly not. But I also know that I won't be stuck on the side of the road wondering if my HPFP died, or if I ran out of gas (assuming the gauge is correct.)
Scott
12-12-2008, 11:45 AM | #14 |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
You can run your car so it says 0 miles safely. BMW expect plonkers to run em low and wouldnt risk failures through negligence.
997.2 GT3
12-13-2008, 05:44 PM | #16 | |
1671
Rep 6,589
Unless you live in the Dakotas or Alaska, or...what is the chance that there is no gas station within 80 miles of your position... The fuel pump cooling thing is a nonsence...or the design is a complete flaw... |
12-13-2008, 10:52 PM | #18 | |||
137
Rep 2,372
http://www.e90post.com/forums/showth...fuel+pump+info BMW said a workaround was not to go below 1/3 tank. Quote:
Scott
12-15-2008, 05:00 AM | #19 |
17
Rep 577
as far as i remember it clearly states somewhere in the manual not to let gas run below a certain level. i think it was 1/4.
12-15-2008, 11:56 AM | #20 | ||
137
Rep 2,372
Page 62 says: Quote:
It has the same warning on page 63 and 113. So if your car averages 20 MPG, 30 miles to go is roughly 1.5 gallons. 1.5/15.9 gallon tank = 1/10th of a tank. If you average 15 MPG (I hope not!!), then you are looking at 1/8th of tank.
Scott
12-15-2008, 12:31 PM | #21 |
59
Rep 2,799
Drives: 2008 BMW E92 328i
haha that would be epic to sneak into the dealership garage and cut it without being noticed...try it
2008 SG E92 328i
iDrive,Premium Pkg,Sport Pkg,Cold Weather pkg,Black Dakota Leather,GP Thunder 8500k cornering,drl,and foglights, ,Blacked Out Grills,Painted Reflectors,Shadowline Emblems,Hardwired Beltronics V-995, AFE Intake, Muffler Delete, Berger tune |
