Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > ceramic tinted windows?
      12-10-2008, 03:29 PM   #1
BMWI6
BMWI6's Avatar
Colombia
96
Drives: 335is
I have a friend who just bought an M5 and he is deciding whether to get normal tinted windows or ceramic. does anyone know the difference? thanks
If everything seems under control, then you aren't going fast enough"
      12-10-2008, 04:34 PM   #2
alan93rsa
Drives: 335i Coupe Crimson Red/Black
The ceramic won't interfere with electronics and will easily outlast the other tints. It is also a more costly item. If wanted to put a light tint on I would go this route. I've tried to find a dealer in Ohio but didn't have any luck. No luck with an email to the manufacturer either.
Alan
      12-10-2008, 04:44 PM   #3
Payroll
Payroll's Avatar
Drives: '08 e92 335i
Location: little place called none of your Goddamn business
There is a lot of information on this if you search. The skinny is that there are three kinds of tint. From least expensive to most they go as follows (price follows the same order):
1. Dyed plastic (I think, but not sure)
2. Metallic
3. Ceramic
The dyed plastic supposedly fade over time. The metallic don't fade, but there is concern that they interfere with electronic components such as comfort access because they contain metal (hence the name). Ceramic tints are considered the best in terms of performance (UV protection, heat deflection, fading resistance) but they are typically twice as expensive as metallic and they take longer to cure (get bubbles out). The two big brands of ceramic of which I'm aware are Huper Optik and Pinnacle. I opted for the ceramic (HO) because I didn't want to risk interference with my Valentine 1, but I'm not sure that metallic would interfere with it anyway.
2008 335i | Space Gray | Blk & Gray Poplar | 6 MT, M3 Lip, Painted Reflectors, Huper Optik 30 (35%), V1 Hardwire, Pussy Magnet
      12-10-2008, 05:59 PM   #4
Joonsup
Joonsup's Avatar
South Korea
322
Drives: E92 M3, E30 325i
2008 BMW M3  [9.50]
2. Metallic
3. Ceramic
The shop I know has from least expensive to most:
1) metallic
2) ceramic
3) carbon
      12-10-2008, 06:13 PM   #5
lib
lib's Avatar
141
Drives: <This space for rent>
While you could pay more for carbon than ceramic, ceramic was more expensive at every shop I visited before tinting my 1er 6 months ago. But, this obviously varies from shop to shop, product to product.
You will most likely have no problems with any of these 3 options, even if you have CA. (Yes, even metallic should be fine but some people have run into problems)
      12-10-2008, 07:12 PM   #6
achenator
26
Drives: 2017 LBB M2, 2017 R8+
I noticed a decrease in CA performance on my e90 M3 immediately after my Huper Optik ceramic was installed. It sometimes is slow to react. It worked perfect up to that point.
      12-10-2008, 08:32 PM   #7
gos
27
Drives: E90 330xi
Wierd, mine works fine with the HO Stark 30. The HO Drei is metallic, are you sure you got the Stark ?
Which opacity?
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC
      12-13-2008, 10:28 PM   #8
achenator
26
It's 30. I have to go back to get the 2 fronts re-done due to some scratching issues. I'm gonna have a look at the box if I can.
