Master Window Switch not working
05-16-2022, 06:16 PM | #1 |
Rep 47
Recently I got splashed with the driver window down. Ever since my master window switch does not work anymore. I can't roll down any windows nor can I use the window lock button.
But, I can still adjust my (power) mirrors. Any ideas what's broken? (Btw my car does not have power mirrors/seats if that matters) |
05-17-2022, 10:52 AM | #2 |
127
Rep 247
got splashed with the driver window down -> window switch does not work anymore
Electronics + water = not working electronics. Take the module apart and examine damage/buy new. |
05-18-2022, 04:41 PM | #3 | |
Rep 47
Either way, are there any good aftermarket switches? |
05-18-2022, 06:23 PM | #4 |
1918
Rep 13,119
You can buy the OEM pod on ebay or amazon for around 50 bucks last
time I looked. You might try removing the current one dipping it in a solvent then drying it under low heat. There is a lever that releases the whole pod. The connector itself could be retaining water. So I would blow out the connector and try to let it dry. Also you could clean the switch pod with a solvent and try to dry it in low heat of out in the Sun. Test switches before you put it in place. There are a bunch more DIY video's on ytube like this Search e90 master window switch. https://www.amazon.com/Electric-Mast.../dp/B07JZXBDFG Last edited by ctuna; 05-18-2022 at 06:38 PM.. |
busted323i0.00 |
05-21-2022, 11:50 AM | #5 |
Rep 47
Update:
Board is fried lmao New Chinese board on the left, old OEM board on the right. I see there are some differences (notably the amount of capacitors) Did I get the wrong board? I've got no power seats/power folding mirrors so I got P/N 61319217326. |
05-21-2022, 05:52 PM | #9 | |
Rep 47
-Red lights when low beams on What is acting off: -When plugged in, the left side mirror instantly goes down-left, motor keeps whirring after max position reached (no buttons being pushed) -Window lock switch works sometimes, sometimes the green LED flickers What doesn't work: Everything else Could this be a fuse issue? |
05-21-2022, 08:11 PM | #10 |
1918
Rep 13,119
Window switches should have nothing to do with lights .
If your having problems with lights the FRM module controls that. Not likely a fuse issue stuff without fuses doesn't work. You need BMW diagnositcs or the equivalent. If everything else doesn't work does that mean the car doesn't start You are being to vague. Last edited by ctuna; 05-21-2022 at 08:21 PM.. |
05-22-2022, 10:07 AM | #11 |
127
Rep 247
I would bet the chinese PCB is just not working as the previous OEM one.
busted323i0.00 |
