BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      12-09-2008, 05:34 PM   #1
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Arrow E92 M3 Factory Alignment Specifications and Ride Height
Ride height:
From bottom of rim to fender.
18" Wheels
Front: 610 mm
Rear: 594 mm
19" Wheels
Front: 623 mm
Rear: 607 mm
Competition package: -10 mm from above specs.
      12-09-2008, 11:31 PM   #2
CodeRed
Drives: '08 E90 & 67 Alfa GTV
Thanks!
      12-10-2008, 12:47 AM   #3
gthirtyfizle
gthirtyfizle's Avatar
191
Drives: E92 M3 AW
Nice, where did u do it?
      12-10-2008, 02:24 AM   #4
schnell325
Bored at work....
schnell325's Avatar
890
Drives: 2016 F82 M4 GTS//2022 M235iGC
Very nice.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      12-10-2008, 10:05 AM   #5
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
dealer
      01-26-2009, 03:03 PM   #6
Schnorbitz
Schnorbitz's Avatar
Scotland
Drives: 318d
Mods - Any chance we could get this on a sticky?
      01-26-2009, 04:29 PM   #7
JJM335
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
These are from the alignment I had my dealer do as part of delivery. I had to type them out because the printout doesn't scan well. Anyway, they are actually generic to the E9x 3 series. The only difference is that you can get more neg camber in the front of an M. Mine is set to -1.3(left) and -1.2(right) with the guide pins in place (incidentally the max I could get from my 335 was -0.5 and -0.7 with the pins out). It handles very well, but I am fairly certain it will scrub the outside tire edge when I autocross and I will end up pulling the pins, going for the max neg. camber (I have read you can get around -1.5) and setting the toe to 0 deg.
Front:
Camber = -0.2 to -0.8
Caster = around 7.2 (this appears not to be adjustable)
Toe = 0.03 to 0.20
Total toe = 0.07 to 0.40
Steer Ahead = -0.05
Rear:
Camber = -1.6 to -2.1
Toe = 0.10 to 0.20
Total Toe = 0.20 to 0.40
Thrust Angle = -0.07 to 0.07
      01-27-2009, 07:37 PM   #8
jml
jml's Avatar
128
Drives: X5M, GT3RS, GT4
Tried to get a more track friendly alignment today. At stock ride height they could only get -1.4 in front. Looks like I'll need plates.
      01-27-2009, 08:24 PM   #9
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
89
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
I only got -1.3 out of my front end.
So what's the consensus on who to buy from?
Dinan
TCKline
      01-27-2009, 08:40 PM   #10
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
I don't think anyone's bought camber plates on this forum yet.
      01-27-2009, 10:05 PM   #11
jml
jml's Avatar
128
Dinan
TCKline
GC has some available, that's what I would probably go with given my positive experiance with their products on the E46. EDC presents an issue apparently (connector on the top of the shock). I am buying a set the moment they are available.
The dinan units are not really camber plates as they only add -0.7 degree, which is not nearly enough.
      01-27-2009, 10:09 PM   #12
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
but just for street driving, you probably don't want to go too much, i.e. more than -2 deg, because that is just going to wear out your tires...
      01-27-2009, 10:21 PM   #13
jml
jml's Avatar
128
Then why bother? There is absolutely no reason for more than 1 degree on the street, and unless you go at least -2.5, no reason to bother for the track either.
      01-27-2009, 10:35 PM   #14
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
exactly. really if one's only driving on the street, there is no need to go beyond factory specs.
      01-28-2009, 04:15 AM   #15
MentholGuy
MentholGuy's Avatar
189
Drives: 11 E90 M3
Cool, Thanks.
I'm going to get my M3 aligned soon,
Should I print out stock M3 spec chart to the shop or just let them use e9x 3 series spec chart since they are same?
      01-28-2009, 04:26 AM   #16
spectrumphoto
Just another peanut in the Turd!
spectrumphoto's Avatar
92
Drives: g16M850;f30M550;f80M3-ED;e90M3
Does the e90 M3 utilize the same specs or is it different???
      01-28-2009, 07:51 AM   #17
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Originally Posted by MentholGuy View Post
Cool, Thanks.
If you are aligning at a dealer, then no need to print out. If at some other shop, then I would print it out.
      01-28-2009, 07:51 AM   #18
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
don't know. ask your SA
      01-31-2009, 02:47 PM   #19
Realpimp23
Realpimp23's Avatar
Germany
11
Drives: E93 M3 JB
thx
      03-01-2009, 02:08 AM   #20
e36jakeo
36
Drives: 2008 M3 6 Speed MT!
I am not sure I agree with this. If you have some good twisty roads that you take at a fast pace, the stock alignment will prematurely wear the outside of your front tires (mine are suffering). I think -1.5 - -2.0 might be about right to make mine wear more evenly while performing better in the twisties and the occational track day.
Also, if you go with the optimal -3+ for the track then you are likely to get pretty big oversteer, so then you need to adjust the rest of your suspension. I'd guess -1.5 - 2.0 would be neutral handling with significantly lessened shoulder wear.
Driving sideways: It's not faster, but damn it's more fun!
      03-25-2009, 01:46 PM   #21
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
Great thread!
I am considering the Dinan springs, and wondering if I should have the camber plates installed at the same time since the suspension will be pulled apart anyway. The two sets of tires I've used are worn out bad on the outside. With the extra -.7, one would get pretty close to -2 degrees after the alignment, which would be a pretty good setup I think like jakeo is saying. A couple of questions I can't seem to find answers to:
1. How thick are the Dinan plates? (How much of a reduction in the drop)
2. How much do they weigh?
If anyone has installed them, please let me know. I called Dinan, but can't get a hold of anyone there, and my Dinan dealer has not seen any yet, so he doesn't know either.
Also, I've read mixed reports on pulling out the pin--if the pin even exists or not on the E9X M3. So, does it exist? And, is the -1.3 max negative camber people are reporting obtained with or without pulling out the pin?
      03-27-2009, 02:36 PM   #22
lucid
lucid's Avatar
374
I got a hold of a Dinan rep, so I'll answer my own question for others who might be interested:
The camber plates are forged aluminum and result in a 1/8" reduction in the drop. They weigh less than a pound. If you max out the stock negative camber setting and add the plates, you'll end up with 2.0-2.1 degrees.
m3post
