05-04-2022, 04:48 PM | #1 |
87
Rep 176
Another Boost issue
Alright so I took my car to the track over the weekend and ran a 7.8 in the 1/8th with a 2.0 60ft. I expected to run a low 7 with the mods listed in my sig, but I coudn't build any boost for a solid launch. I was seeing 0-0.5 psi Using launch control or foot braking to 2k rpm. Can someone take a look at this log and tell me what's going on? I know my IC is not keeping up so I bought a VRSF race. I will check for boost leaks when I install the new IC, but is there anything else
https://www.bootmod3.net/log?id=6272...729b5a761f8c2b
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
05-04-2022, 05:00 PM | #2 |
4376
Rep 7,624
You probably just wont build boost at 2000 rpm with a PS2...?
Your WGDC also looks pretty high for a PS2 in the log considering you aren't really even at target boost. |
05-04-2022, 09:29 PM | #3 | |
87
Rep 176
It also pulled 3 degrees from cylinder 2, AFR drops to 11.7 and it started pulling fuel between 4400-4700 RPM. HPFP is hitting target. It recovered quickly, but im not sure what might cause that.
05-05-2022, 12:25 PM | #4 | |
4376
Rep 7,624
I dont think that explains no boost at 2000rpm, but can explain boost below target and STFT corrections. Usually you dont have fuel corrections on the MM with a flexfuel sensor since the tune is already adjusted. |
