Car Ramps?
12-08-2008, 07:08 PM | #1 |
27
Rep 247
Car Ramps?
Anyone use ramps such as the Rhino Ramps? Do you find the height of 6.5 inches raises the car enough (e92/93 w/zsp). I wanna do an oil change and am trying to decide how tall I wanna make my ramps.
12-09-2008, 01:14 AM | #3 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
I'm a pretty thick guy, and the Rhino Ramps were tall enough for me to install an AE exhaust. However, I could not use the creeper under the front of the car, I had to lay directly on the ground.
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
12-09-2008, 01:23 AM | #4 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
12-09-2008, 11:16 AM | #5 |
42
Rep 403
Drives: 2007 BMW 328i
The ramps are terrific. I have the sports package and they work great !!
I do recommend you get the higher weighted one since the smaller weighted one doesn't look as strong. |
12-09-2008, 11:25 AM | #6 |
Rep 586
I use them to change my oil, they work perfect. I will say however, that in my future I'm hoping to get a real hydraulic lift so I can tinker more. A lift would make it 10X easier to change wheels.
12-09-2008, 07:56 PM | #8 |
27
Rep 247
Thanks, I decided on making mine 7.5 inches high with 5 stacks of 2x10's from Home Depot. Total cost $25 and it works great. This way I dont have the problem of pushing the ramp like many other people do.
12-09-2008, 09:53 PM | #9 |
1477
Rep 409
Specs?
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered-March 7, 2008, Shipped via Graceful Leader-March 21, 2008, Arrived Port Hueneme-April 11, 2008, Delivered-April 21, 2008 |
12-12-2008, 12:45 PM | #10 |
27
Rep 247
Yes! Simply buy 5 qty. of 2"x10"x8ft wood boards. The quality is irrelevant. I paid about 25 bucks total. YOU MAY NEED A WIDER 12" BOARD depending on how wide your tires are.
I wanted my ramps to be 6.5 ft long and I wanted the top level to be 18". That is why I got 8 foot boards. The 18" i cut off the end will leave me with a 6.5 ft piece for the base. In fact each board you cut, each piece will become a part of each ramp. I made each cut at a 45 degree to create a smooth transition. The picture below shows this. After cutting each layer gets glued and screwed together. How much glue and how much screwing is up to you. I used 2.5" screws about every foot or so on the sides. The ramp is only 1.5 tall on the bottom and 3" by the second step so it should handle all but the lowest cars. If you have an abnormally low vehicle with a large front overhang you can extend the bottom piece. I used a 1x1" piece as a wheel stop on the top level. Here it is next to the car. Here they are stacked. They are heavy but are not meant to be portable. |
12-12-2008, 12:49 PM | #11 |
HYEPWR
100
Rep 2,868
^^^ Smart Idea...I did that except I used this crazy material used on the roof of my house...had some laying around
2002 330ci Titanium Silver / Gray
2005 X5 3.0i Black Sapphire Metallic / Black 2002 M3 Laguna Seca Blue / Black 2001 M5 Jet Black / Black |
12-12-2008, 02:35 PM | #13 |
Rep 290
I've used them and they work great. If you've lowered your car, just make sure you have enough clearance.
