'07 6MT-Cooling fan upgrade
04-11-2022, 04:31 PM | #1 |
Rep 18
Hello to whoever's reading this. As the title states, I own a pre-LCI N52 E90 with the 6MT and no towing package, meaning that the car came with the 400W radiator fan. Now, being an idiot, I got into an accident which ruined my fan. (Fortunately, nobody else's car or property was involved in my display of dumbassery.) Continuing to be a dumbass, I went to a pick-and-pull and bought a 600W fan, unaware of the variance between non-M E90 cooling systems. Luckily, I can return it, but I was wondering if I could just upgrade to the 600W fan and reap whatever benefit comes from this. (Additionally, every E90 at that pick-and-pull was an auto, so I'm gonna have to go the online route if I need a 400W fan). I'm willing to do some slight modification if needed.
Thanks for any and all help. |
04-11-2022, 10:49 PM | #2 |
Art Collector
2427
Rep 3,450
Didn’t realize AT and MT e-fans were different! I suppose that makes sense, with the extra cooling loop for the trans fluid.
Having manual-swapped my car without changing the e-fan out, I can say I haven’t noticed anything out of the ordinary. I’d hold onto the one you have
When I'm dead, just throw me in the trash.
04-11-2022, 10:59 PM | #3 |
3975
Rep 7,215
I don't think it will hurt, but there's not really any benefit to the bigger fan. I'm assuming it's there for the transmission cooler. If it fit's and works I'd just go with it.
04-12-2022, 09:54 AM | #5 | |
Rep 18
However, I'm wondering if you switched out the wire harness to the fan? It seems as there may be a wiring incompatibility between the 600W fan and my harness. |
04-12-2022, 09:58 AM | #6 | |
Rep 18
This and wiring differences are what concern me. I found some diagrams of the wiring on this forum, but the links seem to be broken, which makes things harder. |
04-12-2022, 03:20 PM | #7 | |
278
Rep 657
04-12-2022, 06:29 PM | #8 | |
Rep 18
Edit: Looking throught the image again, I see that there's seemingly a difference with the pins. Do you think this is significant? I've marked up the 600W diagram with the 400W values in red. Last edited by Peter_Griffin_Gaming; 04-12-2022 at 06:38 PM.. |
04-12-2022, 07:11 PM | #9 |
3975
Rep 7,215
I think they are the same, but the pins are numbered different. Just compare the plugs - it's only 3 wires, red/blue for power, brown for ground, and black for the PWM signal from the DME. Worst thing happens, you can either splice the plug or swap the pins if needed. the fan control module itself is built into the fan, and they all work basically the same (power, ground, PWM signal).
04-12-2022, 08:51 PM | #10 | |
Rep 18
05-09-2022, 02:29 PM | #11 | |
322
Rep 624
Have you installed the 600W fan in your car yet? Was it plug and play (fingers crossed)? Thanks. Cheers! |
05-09-2022, 03:58 PM | #12 | |
322
Rep 624
05-11-2022, 10:34 AM | #13 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
I'd just splice the 600w connector on, both ends. Solder + heat shrink, or if solder worries you (vibrations, cracking, blah blah big debate) then just use waterproof crimps.
Finding manual specific stuff is always fun!
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
Clammy321.50 |
11-08-2022, 07:57 AM | #14 | |
Rep 18
However, it's making a bit of noise on shutdown now. If it ends up breaking, I'm just going to fit a 600W fan as you described. I have no desire to try and find the 400W unit at a good price. |
