UUC sway bar noise issue?
12-06-2008, 05:59 AM | #1 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
I had the UUC sway bars installed couple weeks ago along with the KW V3 coil overs. I noticed that there is an annoying screeching noise coming from the front suspension. I brought it back to the shop that did the install for some other work. They also looked for the source of the noise. It seems like it is coming from the sway bar moving around in the PUR bushings. Any one have a similar problem? Thanks~
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
12-06-2008, 11:09 AM | #2 | |
111
Rep 1,764
Orb |
12-06-2008, 01:28 PM | #3 |
481
Rep 8,828
Drives: SMB F83
Thanks~ I'll ask my shop to look into it. The noise is really annoying during low speed city driving going over bumps.
12-12-2008, 10:30 AM | #4 |
74
Rep 1,288
Drives: 135i
Grease Kev....shit tons of grease
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
12-12-2008, 10:37 AM | #5 |
481
Rep 8,828
Drives: SMB F83
Is copper grease ok?
12-12-2008, 07:07 PM | #7 |
69
Rep 1,239
Yeah, just grease them liberally. I've had really good results with amsoil's marine grease (purple) if you're looking for specifics. Great durability, holds up to the elements, and no noise.
12-12-2008, 07:13 PM | #8 |
481
Rep 8,828
Drives: SMB F83
Thanks~ I'll let my tech know.
12-12-2008, 07:37 PM | #9 |
69
Rep 1,239
Just another heads up. Most shops will use lithium grease which has great lubrication properties but may have to reapplied after a harsh winter. If the sound won't bother you till the end of next week (I'll be back then), I can give you a tube of the grease I used. Otherwise, look for something with durability, it's a huge mess to reapply that gunk.
