What is gonna break next?
03-18-2022, 06:20 PM | #1 |
39
Rep 155
Just had a/c compressor fail last year, and now, the water pump failed at 90K miles now. What else is going to fail? Can I do preventative replacements to get it done cheap? Thanks! This is a 2008 E93 with N51.
6/4/2018 OFHG changed 10/20/2018 VCG and ESS replaced 1/16/2020 Replaced all 6 ignition coils (Delphi) 9/21/2020 Accident. Entire engine replaced with a used engine with new OFG, VCG, OPG etc. @ 83303 miles 1/18/2021 Replaced ignition coil number #5 1/25/2021 Replaced all spark plugs 5/26/21 AC compressor + Drive belt replaced @ 85336 miles 8/7/21 Replaced left tail light 12/14/21 Oil Change 2/16/22 All tires changed to Michelin PSAS4 @ 90024 miles 3/8/2022 Water Pump + Thermostat failed. Replaced @ 90500 miles |
03-18-2022, 07:02 PM | #2 |
Is it the shoes!?
3884
Rep 5,112
Mickey mouse flange
03-19-2022, 02:19 PM | #4 |
1085
Rep 1,677
DISA valves. When the large one breaks, debris can get sucked into the cylinders.
https://www.e90post.com/forums/showthread.php?t=1510929 3-way CCV vent hose. The plastic becomes brittle and crack. Crankcase pressure can build up and cause oil leaks. https://www.e90post.com/forums/showp...49&postcount=3 You may still have the older 1.1Kw starter. Some say the grease or whatever it was causes the starter to stick itself to death. The starter would crank like a weak battery, when the battery is still healthy. I put in a TYC 1.2Kw starter. I think most newer ones are 1.2Kw too. Avoid the 1.1Kw ones I still see out there. https://www.e90post.com/forums/showp...3&postcount=18 Cheap plastics in the cooling system. https://www.e90post.com/forums/showthread.php?t=1901410 Check the belt tensioner. When it fails the belt walks off the pulley and then can get ingested by the engine through the front main seal, killing the engine. https://www.e90post.com/forums/showthread.php?t=760380 https://www.1addicts.com/forums/show....php?t=1465596 |
StradaRedlands4965.50 greenberet12338.50 |
03-19-2022, 02:28 PM | #5 |
3542
Rep 3,055
You cannot look at the short term expenses, I've owned two 3 Series since '09 and think that it's all about the monthly average for maintenance.
19jdog86.50 StradaRedlands4965.50 |
03-31-2022, 12:09 PM | #6 | |
39
Rep 155
Thanks! A few questions
1. Will the DISA valve will throw a code before it starts to break, which will give me time to replace it, or does it suddenly fail? 2. Same for the 3-way CCV hose. Will it display obvious symptoms before breaking/damaging anything? 3. How can I check which starter I have? 4. I think they changed my Cooling Hose w/Plastic Connector when I got my engine replaced, so hopefully that won't break. 5. I will keep a close eye on that belt tensioner Quote:
03-31-2022, 12:52 PM | #7 | |
1085
Rep 1,677
1. DISA will not throw a code. The connector has only 2 pins and I do not think it provides feedback as to flap position. This is such an unreliable, cheap ass design.
You might hear rattling sounds at the intake manifold. From what I read, the large DISA flap breaks apart and the main problem is the pin can get caught in the valves or get ingested by the engine, killing it. The broken flaps are too large to fall into the cylinder in most cases. My engine seems to have more low end torque after replacement, and the rattle noise is gone. Both valves looked ok on inspection. But given this is a known problem, I just replaced them. I used cheap Uro valves, fingers crossed. If these fail after the 2-year warranty period, I will get Rein ones which are supposedly OEM Mahles with the logo ground off. DISA noise: 2. In my case I lost some crankcase/manifold vacuum, and there was oil seepage at the oil filler cap and valvetronic motor gasket (football). Replaced that hose (and 6 intake manifold gaskets, along with the starter and alternator voltage regulator), tightened the football screws a bit more and solved the seepage. I should use more RTV on the football as I still get a whiff of oil fume once in a while. 3. Either Bosch or Valeo. I am not sure if the stamping on the motor body is visible, but mine had Bosch stamped on it. I put in a Rock Auto $75 TYC starter with lifetime warranty. So far so good, fast and strong cranks. New aluminum bolts torqued to yield of course, using a Harbor Freight pivot ratchet and an Amazon e-torx socket set (14pc set around $15). 4, 5. Just keep an eye on those. Change them when the time comes. Examples: Quote:
04-01-2022, 10:00 AM | #9 |
17386
Rep 18,777
How did an accident cause a complete engine failure?
E93Seattle (Racerbruce)799.50 |
06-24-2023, 07:22 PM | #11 | |
654
Rep 815
(fwiw, that VW actually cost more to fix - replace the oil pan - than it cost to replace the oil pan on my car. It also took forever to get the parts as I think they had to send to Germany for them. Dang VWs.... ) What were you doing where a rock hit your oil pan in such a way that you didn't notice and kept on driving? To your original question though, I have to say that aside from the new engine (which given the "accident" doesn't count as far as something breaking) and the tail light and AC compressor, everything else is routine or otherwise maintenance. All things considered, if this is your total list, your car has been pretty reliable. For a BMW or really just about anything. Last edited by jsunma; 06-24-2023 at 07:32 PM.. |
06-24-2023, 07:35 PM | #12 | |
39
Rep 155
I didn't realize the extent to the damage, it warned me of oil low, but I was stupid enough to ignore it. I was 14 miles deep on a very bad road, so I was being optimistic and thought I can get out before all the oil leaks. Cost me $1200 just to tow it out of the road.
06-24-2023, 07:42 PM | #13 | |
654
Rep 815
So I leaned how to replace the heads on my car. And in the subsequent 30 years, I've also learned not to ignore dash lights for things like oil or coolant. :-) |
StradaRedlands4965.50 E93Seattle (Racerbruce)799.50 |
06-25-2023, 09:04 AM | #14 |
17386
Rep 18,777
Thanks for the quick response, I was wondering...
