Mic not working after coding bluetooth
03-09-2022, 02:37 AM | #1 |
Rep 12
Hi, I bought a 2012 e91 that had a combox but not Bluetooth and was able to code it in. My problem now is that neither the voice input nor mic during calls is working. I have seen some places that I need to repin some pins on the mic connector behind the glove box but I only has 3 wires on both ends which are connected to each other. Would I have to run 3 wires from the glove box to the combox in the trunk?
It's been a bit since I coded in $644 if I remember correctly so if I need to add any more vo codes which one? 606 Navigation System 620 Voice Input 698 Area-code 2 6FL Usb-/audio Interface 6UH Traffic Information 6VC Control Combox 7KD Navigation Business These are the options that came with the car, any help would be appreciated greatly |
03-09-2022, 11:29 PM | #3 |
463
Rep 2,768
you can check combox connector, if it has wires coming to mic pins
if not, you need to run cable from combox to glovebox mic junction and repin junction
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
03-10-2022, 12:46 AM | #4 |
Rep 12
